taking a step into the dark side
Old Dec 29, 2009 | 10:52 AM
sh!ft's Avatar
Who the fack changed my title?!
Default taking a step into the dark side
Ok so this question is sdirected ONLY to the mature knowledgeable experienced mechanics.
I'm thinking about buying a 454 4 bolt main and converting to 502 or 572 specs. What all is needed to convert? I know bore and hone n **** like that, but do I need to change cranks or rods? Any thing else like oil/fuel pumps or water pumps? What heads should I use? Oem 454 or a set of alu. Edelbrocs etc? It would be going into a 70's nova....for street
Old Dec 29, 2009 | 01:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: taking a step into the dark side
a quick search found me this (im not clowinging you i just looked on a few chevelle boards.
stock 454 crate b/s: 4.25 x 4.000
stock 572 crate b/s: 4.56 x 4.375
i am still looking for deck height specs, but just looked at the bore and had a brain fart. the difference between 4.250 and 4.560 is NOT 30 thou hahaa.....has been a long day. depending on the thickness of the walls, you are looking at a .310 over bore. most stroker kits for the 454 net 496 cid.
this is where i got my info from, it is a gmpp catalog.
hope that helps.
http://www.who-sells-it.com/cy/gm-pa...-fullsize.html
Dead CIVIC
Jun 30, 2010 10:46 PM
hondamark35
Jan 19, 2008 10:50 PM
AK94GSR
Oct 30, 2007 01:46 PM
ludelvr
Nov 19, 2004 06:23 PM
