ob2 ls in 1997 civic
Old Dec 29, 2009 | 10:32 AM
ej15012's Avatar
Default ob2 ls in 1997 civic
having some trouble getting my obd2 ls to run. im using the automatic ex harness. my car starts. it will run for like a minute. but dies. it also dies as soon as you give it some throttle ? could anyone give me some help asap
Old Dec 29, 2009 | 12:00 PM
94CivicSi's Avatar
Default Re: ob2 ls in 1997 civic
Check your chassis grounds.
Any CEL's?
What ECU?
Old Dec 29, 2009 | 12:04 PM
ej15012's Avatar
yeah there are cels. and im using a obd2 dx 5 speed computer
Old Dec 29, 2009 | 12:28 PM
94CivicSi's Avatar
It's not going to run, or run right, on a P2E.
'96-'98 P75 will be plug-n-play for you if you've got it wired right.
Old Dec 29, 2009 | 12:30 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Yep, there's your problem. Both of them.
An LS won't run right on a dx computer. And your CELs probably tell 95% of what the problem is if you scan the codes.
Start by getting a P75. Then, if it's still throwing codes, scan them and post them here.
Old Dec 29, 2009 | 01:14 PM
ej15012's Avatar
okay on the dx computer i threw codes p0118 p0113 and for iac.
on the p75 i tired i threw the same thing and one for vtec
Old Dec 29, 2009 | 01:27 PM
B16acivicsedan91's Avatar
The auto harness is the biggest issue, 96-98 civic auto harnesses are crap for 5 speed b series swaps you need a 5 speed harness.
Old Dec 29, 2009 | 01:35 PM
-__-'s Avatar
okay here. your auto harness has a 3-wire IAC valve clip i believe. the 5 speed motors use a 2-wire IAC clip. u need to grab a 2-wire clip and splice it to ur harness.
Old Dec 29, 2009 | 01:43 PM
ej15012's Avatar
i have the motor harness for the ls. i just do not have the harness for in side the car. i know the iac and air intake or what ever are the same ? and i cant find the wire for one of them. then the sensor next to the map on the top. i found to plugs that go into it im not sure what one goes there either?
Old Dec 29, 2009 | 01:56 PM
You cant use that teg harness regardless, You just need it to cut a few clips off it to use on your current harness, I used an ex harness for my c1 swap cause its plug and play and like to avoid all possible headaches.
Old Dec 29, 2009 | 02:01 PM
ej15012's Avatar
what all clips doi have to cut off to use my current harness. is there anyway you could show a diagram or some picture or something. ive never done a b series swap. im just tryin to get it done cause im out of a car and the only reason i did the swap is cause my single cam blew up and i had a ls laying around i was going to build
Old Dec 30, 2009 | 06:03 AM
94CivicSi's Avatar
Spend some time here: https://honda-tech.com/forums/hybrid-engine-swaps-18/gathering-ek-wiring-information-558245/
Old Dec 30, 2009 | 06:32 AM
itsnotfast's Avatar
I believe the when you change the IAC plug from 3 to 2 wire you need to repin 2 wires and cut one in your ECU A plug.
Old Dec 30, 2009 | 09:32 AM
ej15012's Avatar
okay so i re did the iac and still nothing. is there anyway its not getting enough fuel?
Old Dec 30, 2009 | 12:15 PM
94CivicSi's Avatar
You did as itsnotsofast described?
Old Dec 30, 2009 | 12:32 PM
ej15012's Avatar
yes i have this done..
<a href="http://s2.photobucket.com/albums/y16/anthony4u/?action=view&current=gay.jpg" target="_blank"><img src="http://i2.photobucket.com/albums/y16/anthony4u/gay.jpg" border="0" alt="Photobucket"></a>
Old Jan 1, 2010 | 09:21 PM
ej15012's Avatar
problem was fuel rail wasnt getting enough fuel
bostoncal
Mar 28, 2006 02:15 PM
Unjockable
Jan 25, 2005 09:55 AM
PhreeStyleHB
Nov 9, 2004 05:00 PM
