2.0L bottom end good for roadracing if you're currently a B18C5?
Old Sep 3, 2002 | 03:37 PM
GQ 05YellowEVO8's Avatar
Default 2.0L bottom end good for roadracing if you're currently a B18C5?
I was wondering, would the 2.0L bottom end be reliable for road racing, and constant high RPM driving?
Old Sep 3, 2002 | 03:40 PM
Reid's Avatar
Global Moderator
Default Re: 2.0L bottom end good for roadracing if you're currently a B18C5? (VTEC-MAN95GSR)
What 2.0L bottom end?
What compression?
Which rods/pistons?
Which crank?
How high is high rpm?
Road racing isn't really sustained high rpm driving.
[Modified by Reid, 2:40 PM 9/3/2002]
Old Sep 3, 2002 | 03:42 PM
Eric R's Avatar
Any well built engine is reliable for road racing!
Black R's Avatar
25 Year Member
Default Re: 2.0L bottom end good for roadracing if you're currently a B18C5? (Reid)
type R motor with stock crank, custom pistons @ 13:1, 84.5mm bore compression and stock length rods with spec c's...
Old Sep 3, 2002 | 03:44 PM
What compression?
Which rods/pistons?
Which crank?
Any professionally built 2.0L bottom end,
13:1 compression, GSR crank, Eagle Rods, IB Spec Pistons, Toda C's or Jun 3's
Old Sep 3, 2002 | 03:47 PM
Big Phat R's Avatar
Why wouldn't it? What are you worried about?
Old Sep 3, 2002 | 03:48 PM
Reid's Avatar
Global Moderator
You're good to go.
Old Sep 3, 2002 | 04:08 PM
ZygSpeed's Avatar
Define reliable!
Do you expect a "race" motor to last for years and years, or just be able to finish the first few events?
Old Sep 4, 2002 | 12:24 PM
Christian's Avatar
So far I have no complaints at all.... I have only done three events with this engine but so far so good.
accord_raffi
Aug 2, 2008 02:26 PM
delslo93
13
Feb 26, 2005 07:56 PM
Unsung
May 31, 2003 10:11 AM
B19CivicHB
Mar 7, 2002 07:54 PM
