No Spark?
Old Dec 28, 2009 | 08:37 PM
jun10r27's Avatar
Default No Spark?
Hey i recently posted something about not getting my fuel pump to work properly. but ive fixed that problem. thanks for all the help. but Now a new problem is at hand. im not getting spark. it cranks and fuel is getting in. but no spark. brand new plugs. brand new coil packs. fuses are fine. All grounds are hooked up. Any ideas?
D17A2. is the motor.
Old Dec 29, 2009 | 09:09 AM
delsolproblems's Avatar
Default Re: No Spark?
Check the ICM. If it's ok, check the distributor sensors.
Old Dec 29, 2009 | 10:45 PM
jun10r27's Avatar
Ok so i checked the continuity of the grounds on the coil pack plugs. they are all grounded.. they work fine. i turned ignition on and had 12v between the middle hole in the plug(ground) and the left Hole in the plug(Wire going to J/C C 102).the third one i tested to ground and had no continuity. tested to Power (Wire going to ECU) and got 6v. hmmm?gonna get a test light and see if i dont get a pulse when i crank it. i dont think i will. but then what? Crank Pos sensor? gonna check that too. im pretty sure its hooked up. it cranks and im getting fuel. and brand new plugs. all fuses are fine. maybe a relay bad? main relay 1&2 are fine. Anyhting else im missing?
Heres a couple pictures of the diagram hope this helps you Help me lol....
Old Dec 30, 2009 | 07:14 PM
How did you come to the conclusion that none of the plugs are sparking? If none are sparking, the coils aren't the problem. You'll want to check the TDC sensor and the Crank position sensor with a meter. Measure the resistance across the terminals of each. The proper resistance specs and testing procedure should be in your manual.
Old Dec 30, 2009 | 08:45 PM
builthatch's Avatar
MiG-21 superfan
wait, is there an ignition control module w/ that setup? you know, something like an ignitor on a traditional coil setup, but obviously somewhat different considering you run COP...
just curious.
also- do you have another ECU to try?
OP, where are you located in south jersey?
Old Dec 30, 2009 | 09:21 PM
jun10r27's Avatar
i found and fixed the problem.
Old Dec 30, 2009 | 09:38 PM
builthatch's Avatar
MiG-21 superfan
Old Jan 1, 2010 | 08:23 AM
Dogginator's Avatar
Daisy... Daisy...
And what was the problem?
Old Jan 1, 2010 | 08:53 AM
fcm's Avatar
fcm
Old Fart
Ditto that^^^
Don't just leave us hanging. 94
arcticbluealex
Jul 8, 2014 08:06 PM
Honda FTW
Sep 12, 2008 04:01 PM
tyler100
Aug 24, 2008 06:28 AM
Westracing33
Oct 20, 2007 10:02 PM
ludedudeh23
Jul 6, 2004 09:56 AM
