Honda surging idle..FITV cleaned
Old Dec 28, 2009 | 07:54 PM
metalnepal's Avatar
Default Honda surging idle..FITV cleaned
so heres my story..my 1995 honda civic ex idles roughly at cold temperatures..i recently changed the battery, spark plugs, wires, distributor cap and rotor too as one morning she did not want to fire up..it was a cold morning.
now since it was idling bad, also getting shitty gas mileage, read some threads and found problems with FITV and idle air valve were major culprits, so took them apart (FITV) completely cleaned them put it back together no results yet found..also cleaned the idle air valve..
now the car revs up and down at cold starts until it gets warmed up..and comments..where should i look for other culprtis?? main relay??? intake gaskets?? anyone else has a problem like mine??
also i live in MN so it gets pretty cold up here..i just dont wanna be estranded by the car not starting up as it did a few times already..please help..desperately..
Old Dec 30, 2009 | 01:30 PM
EFPhilly's Avatar
Default Re: Honda surging idle..FITV cleaned
check all places for vacuum leaks. Adjust the fitv down with two screw drivers, install new gaskets...
Old Dec 30, 2009 | 02:57 PM
jooky5's Avatar
You might need to re-learn the ecu to adjust to the clean parts.
Old Dec 30, 2009 | 03:12 PM
ennohohbee's Avatar
my 93 coupe with a b16 is doing the SAME thing
im switching on maps now to see if that fixes it
Old Dec 30, 2009 | 08:19 PM
metalnepal's Avatar
How do i re-learn the ECU?? never done that..any instructions??
Old Dec 30, 2009 | 08:29 PM
itsnotfast's Avatar
You might just have some air in the coolant lines causing the surging idle. Bleed the cooling system first, it's the easiest thing to do.
Old Jan 4, 2010 | 08:51 PM
metalnepal's Avatar
i did bleed the system..nothing's changed..yesterday it got cold to -16 F here, she did not start...really need some help here.. how do i re-learn the ECU? is it a coolant sensor?? i don't have the check engine light on..
Old Jan 4, 2010 | 09:57 PM
SouthSider13's Avatar
Had the same problem on my B16a2
Switched the IAC, cleaned it and replaced the coolant but still didn't fix it
But my dad took it to a mechanic and he switched the "injector gasket" (that's what i understood) and now it idles fine
Old Jan 5, 2010 | 06:59 AM
devoxtekxhb's Avatar
To re-learn the ECU, disconnect the batter for about 30 secs. Reconnect it then start the engine. Let the engine idle with no load (do not press the throttle; turn off the a/c and/or heater; turn off all interior and exterior lights; turn of the radio. When the raditor fans cycle twice then it is safe to assume that the ecu has learned the proper idle.
Old Jan 5, 2010 | 08:43 AM
metalnepal's Avatar
hey southsider13, what do you mean by injector gasket??? intake manifold gasket?? or o-rings, was it cold there too?
trouts2
Mar 23, 2012 06:17 AM
DawgC2
Feb 27, 2012 06:12 AM
steelhitman1245
Dec 19, 2011 11:24 AM
EK_MaGz88
Mar 21, 2011 06:32 PM
rsauv
Feb 20, 2007 08:58 AM
