f22 engine be removed without transmission?
Old Dec 28, 2009 | 03:17 PM
Greatness's Avatar
Default f22 engine be removed without transmission?
Can the f22b engine be removed without removing the transmission?
Old Dec 28, 2009 | 03:20 PM
Firefoxracer's Avatar
Default Re: f22 engine be removed without transmission?
Yeah just did it last weekend 93 f22 auto. You will need a cherry picker to do it! now it might be harder or next to impossible with a manual tranny, do to the clutch clearance.
Old Dec 28, 2009 | 09:22 PM
bseriescrxsi's Avatar
auto c an be done.....manual can be done but wouldnt advise it was it requires alot of shimmying and almost precise movements on the motor by a cherry picker and 3 ppl
Old Dec 28, 2009 | 09:29 PM
nus_dogg's Avatar
Thats harder than taking the whole thing out as one piece cause you're gonna be removing the tranny bolts and wiggling the engine as you're pulling it out. It might be easier; who knows.
Old Dec 29, 2009 | 01:17 AM
yea with a manual it will be 100% harder...with an auto not so much...remove the torque convert bolts the rear mont and the bolts connecting the bell housing to the engine and the auto tranny will slide off with little trouble if done right
Old Dec 29, 2009 | 07:41 AM
Greatness's Avatar
crap and i have a manual transmission thx 4 the responses guys
Old Dec 29, 2009 | 09:10 AM
nus_dogg's Avatar
Don't lose hope just yet. You never know if, might be cake with 3-4 friends to help you finish the job.
Old Dec 29, 2009 | 10:35 AM
.inbou's Avatar
why are you just removing the engine and not the tranny?
Old Dec 29, 2009 | 12:31 PM
Greatness's Avatar
swap out the f22 bolt the h22 to the f22 transmission for now.
Old Dec 29, 2009 | 12:57 PM
.inbou's Avatar
Originally Posted by Greatness
swap out the f22 bolt the h22 to the f22 for now.
okay, if you dont have a transmission jack it will be a real pain for sure. the tranny is fairly heavy. This are the main steps you would have to
1. drop center cross member ,
2. remove exhaust,
3. remove driver passenger and front engine mounts,
4. remove harness , clutch line, shifter select etc. from top of tranny
5. passenger side axle
6. remove bolts
7. lower the engine enough so you can slide the transmission about 3 or 4 inches out.
so i would say just take them both out and swap them while the engines out. if you have a friend it would take you 30 min if not shorter, probably about an hour or so by yourself.
Old Dec 30, 2009 | 10:27 AM
Greatness's Avatar
2. remove exhaust,
6. remove bolts
thanks
hany
12
Apr 21, 2007 12:43 AM
drmay
Jan 22, 2007 05:25 PM
bgoetz
10
Aug 29, 2004 09:27 PM
Sonny
Aug 31, 2002 01:35 AM
