Weird Idle
Today after work as I entered the freeway, I could hear a hissing noise. It was my intake, so I put my car into neutral and my idle was from 1k to 3k kept revving up and down.
I turn off the car and turn it back on and same thing happens. Having no choice but to drive I got home going 65-75 mph. As I got off the freeway and popped gear back into neutral I noticed the weird idle was gone.
What could have caused this ??
Temp was fine too
Odometer just broke into the 60k miles
Engine Mods:
AEM cold air intake
RBC air manifold
DC race header
GReddy Evo 2 catback
Temp was fine too
Engine Mods:
AEM cold air intake
RBC air manifold
DC race header
Honda's use a MAP sensor, not MAF.
OP try cleaning out your IACV sensor and resetting the ECU to clear any codes, report back if the problem happens again.
I know that on most older Honda's, if the coolant was low the idle would fluctuate. A buddy of mine also had this happen to his 05 RSX-S. We just topped off the coolant and the floaty idle went away haha. I'm not sure why, or what exactly makes it fluctuate, but I know it can happen from experience. Also happened on my AE86, I had a bad radiator leak and I knew I needed to hurry and top it off if the idle got floaty
I drove the car again about 6 miles, and it didn't do it all..
When I come to a stop for the first 5 minutes start the car
my idles goes up and down for about 2 seconds then lays at about .9k rpm
I have aem cai
rbc mani
dcrh
and greddy evo 2
Well if it was dirty wouldn't it do it often? I ran my car again and it didn't do it .. I will check though
I installed my rbc mani about 4 months ago spilled a good amount of coolant. didnt put more since i was still good. So why would it do it now if it was coolant ? right ?
I have a code due to a messed up 2nd o2 sensor so i need a tech
well the hissing was from my intake filter
I have an aem cai with fujita filter, and while the revving was happening the hissing was loud. after the drive home the hissing was the typical one
I have aem cai
rbc mani
dcrh
and greddy evo 2
Could have let more air into the coolant system. That will raise temps a little and cause your to burn coolant off? Maybe just see if it's low. Again, my suggestion is based of a numerous experiences that I have had. It's prolly not the issue but I can assure it you that it can happen
I will take every ones advise.
Like I said it has been months since I installed my mani, so yesterdays weird idle can't be based on that ..
I hope I'm right lol
lol I can't believe you didn't top off the coolant after installing that, ur goofy
byronl
Jun 14, 2006 08:26 PM
Radiator and all. I hope for you that it fixes your problem though!
