Rear Sedan Seats? and tail light swap
Old Dec 27, 2009 | 11:58 PM
oldschoollove's Avatar
Default Rear Sedan Seats? and tail light swap
ok i got two fast ?
1)i have a 89 sedan and i want a new rear seat what rear seat fit with little or no mod to be done and could u post pics
2) i dont like the 89 tail lights and would like to install 91 tail light or jdm one is there and thing im not to have to do to the wireing or is it just the same ? thanks for the help
Old Dec 28, 2009 | 09:31 AM
Default Re: Rear Sedan Seats? and tail light swap
any one
Old Dec 28, 2009 | 01:33 PM
Old Dec 28, 2009 | 01:35 PM
masterEF's Avatar
you could always try DA seats beacuse i have that in my hatch but their alittle loose sometimes
Old Dec 28, 2009 | 02:26 PM
xpwex's Avatar
1.integra 94-01 rear sedan seats fit. From what i read here at H-T. As far as rear tails for Sedan 88-89 maybe 88-89 Hatchback dunno.
Old Dec 28, 2009 | 03:28 PM
any one got pics of rear seat swap .....and as far as the tail light i want 91 tail from a 91 sedan on my 89 sedan
Old Dec 28, 2009 | 04:21 PM
xpwex's Avatar
I would just throw them on but you might have to extend your harness also.
Old Dec 28, 2009 | 04:39 PM
4drEF's Avatar
Keyboard Humorist
I have my 91 tails for sale if you want to try them out... cheap.
I believe they bolt right up.
http://hondamarketplace.com/showthread.php?t=2631630
Old Dec 28, 2009 | 06:05 PM
91civisedaner's Avatar
To use 90-91 sedan tailights on a 88-89 sedan you will have to cut the metal on your back panel (where your taillights mount to) to clear the bulbs + make sure to get the wire harness for the 90-91 tails you will have to splice wires to make it work (i had 91 tails on my old 89 sedan with the all red 89 center section)
Old Dec 29, 2009 | 01:22 AM
so your saying i have to cut the mounts for the taillight ?then how do i mount the lights im a little lost lol and as far as wire it not just extending the wires
Old Dec 29, 2009 | 01:29 AM
No you cut on the metal on the BODY to clear the extra bulbs,90-91 tails have 2 brake lights per side,just get the tail lights and cheak it out it will make sense.You'll have to splice in to your rear harness because 88-89 tails have 1 brake light per side as 90-91 has 2. I'm tryin' NOT to be a dick but.....Have you ever changed a tail light before???
"you will have to cut the metal on your back panel (where your taillights mount to)" like i said earlier,I can't make it anymore clearer,There is no metal on the tail light just metal mounting studs, the back panel is like a reverse core support where you Tail lights mount to,you WILL have to cut that!! (unless you have a 90-91 shell)
Old Dec 29, 2009 | 01:33 AM
ok cool thanks for the help ...now back to the rear seats any one know of any that fit and have pic
Old Dec 30, 2009 | 09:15 AM
bump
rustanghunter
Mar 20, 2010 03:40 PM
_Keith_
17
Dec 6, 2008 10:59 AM
XooMZ
Mar 21, 2007 04:55 PM
91hatchcivic
12
Mar 14, 2004 02:06 PM
