H23 in 94' accord??
Ive got a buddy who just bought an accord. The engine is pretty much toast. Anyway, he can get a h23 for $600 for the complete swap. Do any of u run this setup and how do u like it? Any info would be appreciated.
that ******* bastard guy!! I had EVERYTHING for an h23 swap but the engines i got were garbage. Its a killer swap if that engine is good for only 600 bones. Run a search, everything is the same cept for wiring, which doesnt require the VTEC wite splicing like the h22a does.
You need to start a thread describing exactly what happened with all your car stuff.
1st h23a1 : I put timing belt/water pump on, all other belts, day before dropping in I hear a "click" when turning crank over. Turns out the valves were bent. 4 of them. The junkyard offered me $300 to repair them. I told them they could buy a $300 spoon to eat my *** and demanded my money or another engine.
2nd H23a1 : Cracked block. Nuff Said.
Man junkyards are so shady I hate them.
They wouldnt swap heads off the 2nd H23 -> the 1st one or you said hell with it?
The F22A1 block I sent to golden eagle ... I got the whole longblock from a junkyard and get this I call him:
Me: I need F22A1:
Him: $200.00
Me: sold.
.... i drive a friends truck to junkyard ...
Him: $450.00
Me: huh?
Him: $250 core for your old engine.
Me: pound sand
I told him to goto hell and what would he want a ragged out F22A1 for anyway except to sell to the next sucker... finally i got outta there @ $250.00.
Me: I need F22A1:
Him: $200.00
Me: sold.
Him: $450.00
Me: huh?
Me: pound sand
a stock h23 with I/H/E msd 6a blaster 2 coil timing was retard at all times
f22b tranny with short tires f22b ecu re-program shifting at 7800-8000rpms
i use to love that engine allmotor ill go to the track and beat gsr's with boltons ,civic si's with boltons ,h22 accord ,b16 civic/crx's
then ill spray and put #'s on the board that no one would believe
out of a car that was 3165 lb with me in it
7800-8000?
thats dumb for a few reasons...but whatever floats your boat
He has it built up pretty goddamn well.
a stock h23
eh?
a stock h23
eh?
meh.....its built now, thats all ize can tell j00.
with stock valve adjustments and stock timing it would peak power @ about 7400rpms
but with vary lose valve adjustments timing well retard running a little lean i could make power till about 7800rpms but i was taking it till 8000 at the track so i could fall back in power band going through the gears
the h23 stops making power before 6500, it sucks on the top end
