car won't start
Old Sep 3, 2002 | 02:16 PM
dumbchild's Avatar
Default car won't start
car ran fine this morning on the way to work. later on get in and turn the key and nothing at all. the start-up lights on the intrument panel flicker and are very dim. and somewhere below the dash something is making a wierd electronic buzzing / grinding noise. the fuel won't prime or anything. basically turning the key does nothing. I don't why my battery would die over a couple of hours (didn't leave my lights on). Gonna try and jumpstart to see if its the battery. But could this be a problem with the main relay or the ignition itself? Thanks in advance.
Old Sep 3, 2002 | 03:06 PM
Redline130's Avatar
Default Re: car won't start (dumbchild)
Could be a number of things. Maybe your alternator died and your battery drained, or perhaps your main relay went out. Sounds like your battery is weak though.
Old Sep 3, 2002 | 03:25 PM
dumbchild's Avatar
Default Re: car won't start (cyber13)
thanks, so would the best way to problem solve this be:
1) try jumpstart - if car starts then = dead battery, replace battery
2) if battery dies again - bad alternator (anyway to check alternator?)
3) if car still won't start - replace main relay
how do I replace / check the main relay - where is it located exactly?
enriquez2000
Dec 27, 2011 10:41 AM
ek coupe
10
Mar 5, 2010 05:02 PM
5spdIntegra
Oct 22, 2007 06:17 PM
ONISHIMA
Feb 7, 2007 09:03 PM
BlueIntegraBoy
Jan 18, 2007 01:53 AM
