So I was screwin' around in the fuse box/engine bay, now my gauge cluster doesnt work
Old Dec 27, 2009 | 12:55 PM
STi-Thrill's Avatar
Default So I was screwin' around in the fuse box/engine bay, now my gauge cluster doesnt work
So in an attempt to get my gauge cluster working, I went into the fuse box and pulled a BIG black fuse with 4 prongs, right above the ignition fuse (I thought the one I pulled was the ignition fuse) so I connected the red (power) wire to one of the prongs and the black wire on my stupid voltage gauge to the batt. ground and started the car, once I noticed the gauge wasn't working I disconnected everything from the gauge/fuse box and now my ENTIRE gauge cluster isn't working, but the lights do work.
The car is a 1994 Accord LX and btw, I didn't check to see if the windows rolled down. Is this just a fuse problem? If so, can I get one of these fuses at a place that would be open on a Sunday night? Thanks!!
Old Dec 27, 2009 | 01:43 PM
bobinator5000's Avatar
Default Re: So I was screwin' around in the fuse box/engine bay, now my gauge cluster doesnt
NEVER EVER EVER short a fuseblock.
If that fuse went, THERE IS A REASON! That reason may be its shorted, might be it was getting too much voltage, might be the resistance in your instrument cluster was too high. Either or, there's a fire hazard and the possibility you're going to blow something else out.
Change out the fuse, see if it works. A Multimeter and a wiring diagram are what you are going to need to check around with wiring issues.
Old Dec 27, 2009 | 01:57 PM
slomofo's Avatar
GDD Member
Old Dec 27, 2009 | 11:02 PM
STi-Thrill's Avatar
WAIT, in searching for a replacement part tonight - I found that it is NOT a fuse, but a relay. I'll stop by the autoparts store tomorrow and see what they've got.
Old Dec 28, 2009 | 04:37 AM
BrayzieEF9's Avatar
Go to carquest there like the 7 11 of auto parts stores lol
Perez_cb7
Jul 23, 2013 10:32 AM
f20cmx5
Jul 4, 2011 07:12 AM
92hatch_cx-t
Jun 22, 2007 06:08 PM
jdmcd7_cali-luv
Jul 10, 2006 07:02 PM
BoostedSi
Feb 23, 2003 08:59 PM
