tire help
i swapped mine out for 195/60/14 bridgestone potenza RE960 AS.
heres the link to tirerack.com for that size: http://www.tirerack.com/tires/TireSe...r=14&x=11&y=13
and a tire size calculator: http://www.miata.net/garage/tirecalc.html
I don't know how they will look with wheel spacers. If you're going to stay with the same size wheel, you can go to a 205-55-14. But those are expensive in my opinion.
but just in case I don't know if you knew this or not, i'll just post it anyways:
195 = width of tire in milimeters
60 = % of width of tire, equal's tires sidewall height.
14 = wheel size in inches
185/65/14 (stock size)
sidewall 4.7in
radius 11.7in
diameter 23.5in
circumference 73.7in
revolutions per mile:859
195/60/14
sidewall 4.6in
radius 11.6in
diameter 23.2in
circumference 72.9in
revolutions per mile: 869
205/55/14
sidewall 4.4in
radius 11.4in
diameter 22.9in
circumference 71.9in
revolutions per mile: 882
If you're gonna upgrade the wheel to a 15in. I'd go with either a 195/55/15 or a 205/50/15
sidewall 4.7in
radius 11.7in
diameter 23.5in
195/60/14
sidewall 4.6in
radius 11.6in
diameter 23.2in
205/55/14
sidewall 4.4in
radius 11.4in
diameter 22.9in
195-60 r14 are what my bro had on his teg a while back
perfect size if you ask me
for 15 inch rims I go with 205-50
and with 16 inch I go with 205-40
but I cant tell you any other rims size cuz i only had tires of that size with me
oh and these tires lined up next to one another is the same size as far as hight goes
