please help me quick car died while driving and now cranks but no start!!! any ideas???
Old Sep 3, 2002 | 02:05 PM
Punisher's Avatar
Default please help me quick car died while driving and now cranks but no start!!! any ideas???
the fuel pump is running when key is on
i layed the plug with the wire on the valve cover and no spark while cranking
it is cranking real good but does not fire up
my car was running perfect today and then while driving it dies and would not start back up
please help me quick, im desperate.
Old Sep 3, 2002 | 02:13 PM
4gvtec's Avatar
Default Re: please help me quick car died while driving and now cranks but no start!!! any ideas??? (Puni
its the distrib.proby top dead cylinder sensor or ignitor or cylinder position sensor.look uder the passenger side carpet and see what code its giving.
Old Sep 3, 2002 | 02:14 PM
4gvtec's Avatar
buy a new one!!!!!!!!! dont get a used one,one from autozone or what ever.like $160.00 with a life time warranty.
Old Sep 3, 2002 | 02:31 PM
Hawkrider's Avatar
From my limited experiences with these things ( has happened once each on 88DX and first 91Si and am expecting it to happen eventually with current one ! ) it has been the ignitor . $90 from your local Hondamart IIRC . The first time it happend I did the whole expen$ive replace rotor/cap/distrib etc first
Old Sep 3, 2002 | 02:46 PM
4gvtec's Avatar
the ecu will tell you what it is.
Old Sep 3, 2002 | 03:15 PM
Punisher's Avatar
and how would i check this from the ecu?
Old Sep 3, 2002 | 03:41 PM
4gvtec's Avatar
pull up the passenger side carpet on the fire wall.theres a metal plate that goes over the ecu.theres a clear hole there.get in the car turn on the key you will see a red led light flash when you do this.from trying to start it befor when it did not start the led should be flashing.with the key on count the flashes and count them.post it when your done and ill tell you.
Old Sep 3, 2002 | 04:14 PM
Punisher's Avatar
i am getting no flashing of the led in the ecu. my check engine light is not on either. i just replaced the plugs, wires, cap, and rotor and still nothing. cranking good, but no go. any ideas?
ps~ thanks a lot for the input so far.
[Modified by Punisher, 1:15 AM 9/4/2002]
Old Sep 3, 2002 | 04:16 PM
Punisher's Avatar
[Modified by Punisher, 1:19 AM 9/4/2002]
Old Sep 3, 2002 | 05:23 PM
pelotudo's Avatar
Distributor rotor screw...almost guarantee it.
I had this happen to me, got it home...took off the cap and the screw that holds the rotor on came out. If it doesn't come w/ a lockwasher, get one or put some MEDIUM STRENGTH (NOT HIGH STRENGTH) locktite on it; won't give you any more problems.
jB
Either that or your threw a timing belt and you have to replace your engine
Old Sep 3, 2002 | 08:37 PM
Punisher's Avatar
niether! i just replaced the cap and rotor and they came with new screws. everything is on tight. and i didnt break the belt. nice try though thanks. anyone else have a clue?
Old Sep 3, 2002 | 09:29 PM
Aron Parsons's Avatar
main relay? i had the same happen to me today, although i get some intermittent starting when hot, always starts when cold (outside temperature). in reading up on it, my problems are about 99% the same as everyone else with main relay problems. search in the archived posts in this forum for main relay and read up, hopefully it will help. only $45 to replace.
Old Sep 3, 2002 | 11:17 PM
Hotrod Honda's Avatar
That's the exact thing that hapened to me with my 89 Si and looked at everything even the main relay box on the drivers side kick panel and it wasn't even that. Anyways I swapped it out for an LS but if you figure it out lemme know please.... we think maybe it was the injectors even though everything checked out at the ends of the leads to the injectors.....
[Modified by Hotrod Honda, 12:18 AM 9/4/2002]
Old Sep 3, 2002 | 11:58 PM
island_son's Avatar
Check the coil.
Old Sep 4, 2002 | 12:10 AM
MOCrxHf's Avatar
I'm having this same problem. Replaced the ignitor, the cap, the rotor, the wires, the map sensor. Cranks but won't turn over.
Old Sep 4, 2002 | 05:04 AM
USDM 4G VTEC's Avatar
Check the coil.
second that
my buddy has an LSVTEC and it died on th ehighway
it all came to be the ig coil... if u have an xtra dizzy change coils.......
that sounds like ur problem
Old Sep 4, 2002 | 06:11 AM
Trinity's Avatar
if it was the main relay the fuel pump wouldn't be coming on
Old Sep 4, 2002 | 06:26 AM
Louie B.'s Avatar
IGNITOR!!!!!!!
This little guy right here! it's inside your distributor and your coil wires go through it. Honda doesn't list it as a "sold seperately" part, but the regular auto parts stores do. This is what happened to mine.
Old Sep 4, 2002 | 06:42 AM
jc836's Avatar
I beg to disagree about the ignitor not being sold by itself by Honda. Anyway-it replace it means taking the distributor apart to get it out. I would go for a remanufactured dizzy in this situation.
Old Sep 4, 2002 | 07:36 AM
Punisher's Avatar
the only dizzy i can get is from an autoparts store, and it is $180 with nothing else included in it. i really dont know what to do. how do you check the coil, cause all i have is a haynes manual and thing is freaking confusing. help me!!!!!!
Old Sep 4, 2002 | 11:54 AM
SqueezinEF's Avatar
do you have an MSD or anything like that or is all stock?
Old Sep 4, 2002 | 04:27 PM
Punisher's Avatar
its all stock because i just bought it a month ago, i havent had time to mod it and its already dead.
Old Sep 4, 2002 | 07:28 PM
Hawkrider's Avatar
It isn't a big deal at all to replace the ignitor - just a couple screws really - and I would deffo give it a try before going with an entirely new distributor . Its a bit of a crap shoot as to whether your whole dist. is shot but I'd lay odds on the cheaper ignitor
AutoZone and Advance weren't able to supply one but the Honda dealers had them in stock .
xSoylentGreenx
Jul 2, 2008 12:10 PM
El Boricua
Apr 7, 2008 04:13 PM
dboz3403
Sep 22, 2007 07:16 AM
jus2sho
Oct 18, 2006 03:44 PM
DougNuts
Jun 26, 2005 02:50 PM
