DA auto to manual swap?; then into CRX?
Old Dec 27, 2009 | 08:29 AM
ryanangelo212's Avatar
Icon2 DA auto to manual swap?; then into CRX?
i found a cheap 91 teg with a good motor, but auto tranny.
my plan is to make it a manual, then swap it into a 88-91 crx si.
so my question is, what all is needed to change the motor from auto to manual, and will the wiring still work from the si?
(i have done a manual ls swap into a crx si before)
Old Dec 27, 2009 | 08:33 AM
akurtzer57's Avatar
Default Re: DA auto to manual swap?; then into CRX?
Auto motor will work just Install flywheel with new pilot bearing and youll be fine.
Old Dec 27, 2009 | 10:36 AM
b18integraboy's Avatar
you also need to remove the egr valve on the motor. you can either my a egr block off plate or buy one or just buy a manual intake manny.
ilikejesus
Apr 10, 2009 01:41 PM
limit
Jan 26, 2009 12:27 PM
Benchracer
Oct 10, 2008 11:50 AM
thrty8street
15
Feb 8, 2004 09:43 AM
