1988 integra no spark!!!
i have a 1988 integra....engine won't start, so i pull the spark plus wires...no spark...what should i change?? i want to know where the coil located. inside the distributor or outside. hope u understand my english. thank you for all helps.
should be inside the dist. at least it is on my 94 teg. but try a diff dist from a buddy or try a new coil if not it take it back, but dont tell then you installed it, they give ya problems sometimes
