NEED HELP!!!!
Old Dec 26, 2009 | 09:43 PM
<jdm_love>'s Avatar
Default NEED HELP!!!!
i put a skunk2 intake on my b16a2 and now the throttle cable bracket is big enough to fit.....which oem bracket do i need to be using in a dc integra for this to work.....
also i am trying to wire up my gm3bar into my integra with my chasebays harness.....the wires on the harness are yellow w/green stripe....green w/ white stripe....red w/ green stripe......which wires go to A B C on the three bar?
thanx for the help
Old Dec 26, 2009 | 09:48 PM
clutchrsx's Avatar
Default Re: NEED HELP!!!!
B-SERIES
A = gnd Green/White
B = map signal White
C = 5v Yellow/Red
For verification check inside the Honda Map sensor plug. The pins may be labeled with V O G - for Voltage, signal and ground.
Old Dec 26, 2009 | 09:54 PM
mouab18c1's Avatar
you can use an ITR tb bracket holder and cable on a skunk2 manifold
Old Dec 26, 2009 | 11:04 PM
<jdm_love>'s Avatar
in my dc integra i have a gsr with b16 head.....what throttle cable and bracket do i need to use for my skunk2 intake mani.....
and please more help on the wiring....
Old Dec 30, 2009 | 01:40 AM
mouab18c1's Avatar
i already answered this for you but i guess you couldnt understand so here it is again,
"you can use an ITR tb bracket holder and cable on a skunk2 manifold"
egboy94
Oct 21, 2009 08:50 PM
b16clutch
Dec 28, 2005 09:55 AM
vtecgod
Aug 24, 2004 08:09 AM
gsr98teg
Feb 6, 2004 02:06 PM
G U E C O
Nov 18, 2003 12:44 PM
