AEM CAI rubbing.....who to minimize it
Old Sep 3, 2002 | 01:46 PM
01-1293's Avatar
Default AEM CAI rubbing.....how to minimize it
I have tried countless materials in between my AC lines and my intake but the rubbing noises do not seem to go away.......anyone have any ideas on the best way to eliminate rubbing.......
[Modified by 01-1293, 2:47 PM 9/3/2002]
Old Sep 3, 2002 | 01:48 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: AEM CAI rubbing.....how to minimize it (01-1293)
I just got a piece of terry cloth between them, has worked great since day one.
Old Sep 3, 2002 | 01:51 PM
B2FiNiTY's Avatar
Try adjusting the mount? Raise it higher?
Old Sep 3, 2002 | 01:52 PM
Warren's Avatar
Wrong-Way Wang
Duct tape is your friend.
Warren
Old Sep 3, 2002 | 02:09 PM
Black R's Avatar
25 Year Member
.....zip ties!
Old Sep 3, 2002 | 02:25 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: AEM CAI rubbing.....how to minimize it (Black R)
.....zip ties!
Yes, zip-tie the AC lines together. Should give you enough room.
Old Sep 3, 2002 | 02:31 PM
Yellow3TypeR's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (Splat)
I put a piece of rubber hose around the AC line. I can't hear the rubbing noises anymore.
Old Sep 3, 2002 | 02:45 PM
Champ R's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (Yellow3TypeR)
Id try duct tape or a piece of rubber/foam between the pipe and any metal. I used to have an AEM CAI and had the same rubbing issues.
Old Sep 3, 2002 | 02:50 PM
Hunter's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (Champ R)
yep, zip ties work perfectly
Old Sep 3, 2002 | 03:12 PM
Bob#455's Avatar
Remove the air conditioning system. No more pesky lines to molest your intake.
Old Sep 3, 2002 | 04:44 PM
Bbasso's Avatar
Just get some muscles and push the lines away from it. its clean, simple and works fine.
Old Sep 3, 2002 | 04:48 PM
1GreyTeg's Avatar
Ditch the AEM and get a Comptech Icebox.
A.
Old Sep 3, 2002 | 07:01 PM
DaRKniGhT ITR's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (1GreyTeg)
Hmm...never had a rubbing problem with my AEM cai...
Old Sep 3, 2002 | 08:13 PM
MyYellowHonda's Avatar
New User
Default Re: AEM CAI rubbing.....how to minimize it (DaRKniGhT ITR)
I only have rubbing problems with the reservior tank, the ac line rests about 3 inches above the intake pipe. Everything i put inbetween the pipe and the tank ends up with a hole in it
Old Sep 3, 2002 | 08:36 PM
tony4311's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (B2FiNiTY)
mine has never rubbed, try adjusting the mount before you move te a/c line
Old Sep 3, 2002 | 09:46 PM
itr501's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (tony4311)
If installed properly, it should not rub. However, it might come very close. What seems like a small gap may actually be a rubbing point. You have to keep in mind that the thing will vibrate, move around, etc. because it is on rubber mounts.
I use velcro pads (the furry side because I wanted my engine bay to rub against something soft if it were to) on my AEM. It seems to work just fine. I suppose the rough pointy side would work as well (might cause scratches in the long run). Watch out for the coolant reservoir. I also had some rubbing at that point. It was quickly remedied by unbolting the reservior mount, pushing it away from the trouble zone and tightening everything back up.
[Modified by itr501, 10:48 PM 9/3/2002]
[Modified by itr501, 10:49 PM 9/3/2002]
Old Sep 4, 2002 | 08:55 AM
Haunt's Avatar
Me Either...
Old Sep 4, 2002 | 09:08 AM
Splat's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (MyYellowHonda)
Mine did that because it was not properly seated on the throttle body. Doublecheck that area. It should clear the overflow tank.
Old Sep 4, 2002 | 11:35 AM
JPP's Avatar
JPP
I gently forced the lines out of the way and zip tied them together + I put heat tape on the CAI, no more problem. I also had rubbing with cooling hoses (the ones that are insulated more toward the back of the engine bay) I repositionned the CAI properly to solve that problem.
Old Sep 4, 2002 | 11:45 AM
PM-Performance's Avatar
zip ties or rip the ac out.
Old Sep 4, 2002 | 04:46 PM
05 600RR's Avatar
That's what I did with mine.
Old Sep 4, 2002 | 04:48 PM
Neo's Avatar
Neo
Default Re: AEM CAI rubbing.....how to minimize it (itr 01-0492)
edit: oops, i hate it when I do that (some how hit enter and make an errant post)
[Modified by Neo, 8:52 PM 9/4/2002]
Old Sep 4, 2002 | 04:50 PM
Neo's Avatar
Neo
Yep, just get a piece of 1" diameter heater hose, cut to a length of about 2", then cut it down the middle like you're gutting it, wrap around the a/c lines, secure with zip ties and you're all set.
Old Sep 4, 2002 | 04:54 PM
skafia's Avatar
25 Year Member
Default Re: AEM CAI rubbing.....how to minimize it (Neo)
I stuck a piece of cardboard between them, it wedges in there nicely and it'll protect the rubbing.
Old Sep 4, 2002 | 04:55 PM
B2FiNiTY's Avatar
Default Re: AEM CAI rubbing.....how to minimize it (skafia.cw.r)
I used to have a peice of rubber hose in between them but it ate at my intake a little bit. Nothing much, just some scuffs.
