Just got F&R sway bars. few Q's
Old Dec 26, 2009 | 09:00 PM
hatch92civic's Avatar
Default Just got F&R sway bars. few Q's
So i just picked up a 19mm rear sway from the junkyard today off a 95 4dr. seems to be aftermarket. does anyone kno who the bar could be made by? The endlinks mount to the out side of the LCA with a bracket attached to the bolt, all others i have seen mount to the LCA its self. where could i find endlinks? also i got a sway bar off a si coupe, i think it is about a 21mm. how hard is it to install it?
Old Dec 26, 2009 | 10:57 PM
Arthas's Avatar
Default Re: Just got F&R sway bars. few Q's
They mount to a bracket? Post some pics dude, that will really help. Pics are worth 1000 words.
To make the Si sway bar fit, youll need Si end links, LCA's, shock forks, brackets, and bushings. I dont know if it will fit an EG. Also, its a 25mm sway bar.
Old Dec 27, 2009 | 05:55 AM
Anon51's Avatar
they're probably ST sway bars. Suspension Techniques. they're the only ones that come to mind that mount to a bracket outside of the normal sway bar link areas that come to mind.
Old Dec 27, 2009 | 07:24 AM
Gunmetal_B20_Hatch's Avatar
Does your LCA have a hole for the endlink??? You will likely need new LCA's too. For the front as well. Honda made 2 different LCA's.
Pics of swaybar and LCA would be suuuuper.
Old Dec 27, 2009 | 09:31 AM
There are no holes in the LCAs at the junkyard or on mine. Aslo I measured the front bar and it is 21mm. heres a few pics of the rear.
and the brackets
Old Dec 27, 2009 | 10:29 AM
Arthas's Avatar
Youre going to need new rear LCA's to attach a sway bar. DX and Si rear LCA's did not have the holes for the sway bar.
Old Dec 27, 2009 | 05:20 PM
Anon51's Avatar
thats the rear for the ST bar i was talking about. you need to remove the bolt that holds your strut and that bracket bolts to that.
Old Dec 27, 2009 | 05:23 PM
Anon51's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/asr-brace-suspension-technique-sway-bar-2636748/ some sample pics of it installed on my car and another users car.
Old Dec 27, 2009 | 06:02 PM
Those will work with your current LCA's They attach to the lower shock mount bolts. You need to get longer bolts though. And GL geting them out cleanly. Alot of times they are seized int eh LCA bushing and the heads break off.
You alos need to find/make some endlinks.
Old Dec 27, 2009 | 07:17 PM
Anon51's Avatar
you don't need longer bolts for the LCA's. i used my oem bolts as you can tell from the pictures in the link i posted.
Old Dec 27, 2009 | 09:19 PM
any ideas on where i could find the just endlinks? i am going to call st tomorrow. would front stock endlinks work? like this one http://www.modacar.com/bolt-on/produ...7817-4964.html
in that link 2 different size endlinks were used? how much did putting the rear bar on ur car help the handling?
Old Dec 28, 2009 | 06:43 AM
Anon51's Avatar
you definitly feel the difference the only problem i still have is torn trialing arm bushing. i'm to lazy to change them right now tho considering its cold and i don't have a heated garage.
BLU CIVIC
Sep 30, 2009 02:06 PM
immajackuup
Apr 22, 2009 12:25 PM
rupensane
Dec 1, 2008 07:00 PM
civicgeek133
Jun 10, 2007 10:51 PM
JMelt4
18
Apr 30, 2007 07:43 PM
