FS: Full OBD1 Integra B18B1 swap
Old Dec 26, 2009 | 06:31 PM
swainsol's Avatar
Default FS: Full OBD1 Integra B18B1 swap
Erik
Nashville,TN
$1000 FIRM
h22swain@yahoo.com: 615-971-1369: PM
This is an amazing swap out of a 1994 Integra LS 139xxx miles almost 140000.
Miles will continue to go up as i drive it everyday.
Swap is flawless probably the cleanest head i have EVER seen.
It was mated to an automatic transmission for the first 138109 miles of its life.
I bought the car and the trans was toast so i decided to swap it to a 5 speed.
Sence i have had it i have changed the fuel filter, rotor, cap, plugs, wires, valve cover gasket, oil pan gasket, flywheel was machined before install and brand ne clutch at 138109 so less than 2000 miles on it.
The trans came from a wrecked 2000 integra when he wrecked it so it has a little over 100000.
Its still in my car so you can drive it see it run whatever you wanna do great motor and trans no doubt.
Comes with everything you need besides shift linkage.
Motor, trans, distributor, harness, ecu, axles, half shaft, starter, anything you need except linkage.
If you have any questions or if anyone wants to see pictures i can get them.
You really should just look at it if your interested and see how well it runs for yourself.
Old Dec 27, 2009 | 12:58 PM
CarGuy75's Avatar
Default Re: FS: Full OBD1 Integra B18B1 swap
Bump for a great price on a LS swap.
Old Dec 28, 2009 | 04:42 AM
swainsol's Avatar
thanks man
jdmh22eg2
Jan 15, 2013 04:25 AM
Excel91CiViCsi
Mid-Atlantic (Sales)
Nov 25, 2010 07:33 AM
simplemanseven
Sep 25, 2008 10:27 AM
Dasfinc
37
Mar 5, 2008 11:59 AM
biglou
17
Mar 4, 2007 10:00 AM
