bearing noise coming from crank area
hey all when it cold outside which is everyday now, I get a loud scraping noise from crank area like a bad bearing in a pulley but I removed all the accessory belts and still heard the noise, is there any thing that the timing belt spins on that can make this noise. I have great oil pressure all day everyday so I dont think its spun a bearing.
What motor are you running? JDM H22A like in your sig?
If its a bad bearing, you'd be hearing a loud knock coming from your engine block or under from the oil pan. Very notice-able. It might be your timing or balancer belt that is rubbing on something, but it would smoke though; because, I've seen it happen to one of the guy I know from another forum.
I'll try to take it apart tomarrow, I hope its something simple. I hear so much of the automatic tensioners failing should I switch to manual or can I use the newer ones from the 01 h22's I read somewhere they were redone and better but do they fit?
Honda fixed the issue. There is a new part number. If you are tearing it apart to see and haven't changed it yet, I'd go ahead and do it anyway. But yea, there is the timing and balance belt in there.
http://www.collectiveracing.net/crfo...aec0acd7fbc9f8
good news its not anything on the inside of the motor or the timing belt, the harmonic balancer has shifted over and its rubbing on the timing cover. is the crank pulley and harmonic balancer 1 piece?? no one carries it so im going to honda tomarrow. will I need a puller to remove the crank pulley or will it slide off after removing bolt?
is the crank pully moving off balance?
It could be just the timing belt cover being loose moving towards the crank but if the pulley moves out of balance than Id remove the pulley and inspect.
Isn't the crank pully and the harmonic balancer the same thing? The harmonic balancer is the rubber part in the crank pulley that dampens vibrations?
yeah its the pulley I can move it by hand. this is one thing im taking to the shop because honda wants 95 for the tool and the local tuner shop will do it with their tool for 70 bucks. I did everything on this car by myself but ima have to sit out on this one.
I hope all it is is the pulley. I had the same noise which turned out to be the pulley shaving the key and chewing up the end of my crankshaft. Long story short crank was destroyed so had to replace it. Hope yours isnt that bad.
RICO_
Honda Civic (2006 - 2015)
57
Mar 2, 2011 07:22 AM
Justinleexxx
Mar 25, 2010 11:32 AM
