Tilton Twin Disk Setup, Sleeved Long Block
Old Dec 26, 2009 | 10:24 AM
3rdshift's Avatar
Default Tilton Twin Disk Setup, Sleeved Long Block
I have a complete tilton twin disk setup for sale, its for a b series. This includes the complete kit. It has a 10lb flywheel, pressure plate, disks, and the complete hydro throwout bearing kit. This is with master cylinder and hydro throughout bearing and stainless line. Everything is brand new and never been installed. Also inlcluded is a set of brand new honda AT trans flywheel bolts needed with this flywheel. Its complete i paid 1800 for everything. Asking 1350$ shipped cheaper then just the clutch setup you chance to save big. ill post pics later give me a call or email me if you are interested 7403347476.
I also have a complete long block race motor. Its a b18b Block sleeve and machined by ERL ITS complete with erl superdeck 1 sleeves, erl 5 main girdle, and erl installed half inch head studs. LS crank micropolished and balanced. It has pauter connecting rods, and JE 84.5mm pistons they are 9.0 compression, and have the double forged wrist pin option. The cylinder head is a b16 head completely port and polished and combustion chambers were matched to the bore size. It has a ferrea valves intake +1 and stock exhaust size. Supertech springs and retainers, all brand new valve locks, seals, everything. It has Skunk2 Pro 1 cams, full race cam gears, golden eagle lsvtec kit, cometic custom head gasket, B and R block fittings -10 for catch can set up. morroso tigwelded aluminum oil pan, morroso matching pick up, and oilpan stud kit, and more. It has a complete meziere electric water pump setup.
Its complete from oil pan to valve cover. Every bolt is new including cam caps and all accessories. Every seal is brand new and from honda. It has a brand new type R oil pump, type R tensioner, and a timing belt. This is a no joke motor, and is complete and ready to go. Its all brand new, i have boxes for everything all machine work was done by ERL. Ill post pictures of everything shortly hear. Also included is a powder coated white valve cover. Let me know if you have any questions or want to come and check it out. I am asking 5500OBO i have over 8k invested and its all new still.
Old Dec 26, 2009 | 03:25 PM
Black-Ty [EG6]'s Avatar
Default Re: Tilton Twin Disk Setup, Sleeved Long Block
bump
krazyhmongboi
Northwest (Sales)
Apr 20, 2011 09:22 PM
3rdshift
Mar 12, 2010 10:27 AM
Andyb22g
Northwest (Sales)
Sep 16, 2005 10:38 AM
lsvtecracer
Jul 28, 2005 04:13 PM
FastEK9
Oct 12, 2004 06:01 PM
