Knocking noise on my y8 :(
Old Dec 25, 2009 | 07:13 PM
JOS-EM1's Avatar
Default Knocking noise on my y8 :(
well kinda got carried away on Christmas eve day and went cruising with my friends. Hitting the freeway I hit redline in third gear, got off the freeway and noticed a knocking noise coming from my engine bay. Took a quick look at it and didn't see anything visibly wrong... I'm guessing it might be my internals, i hope i didnt warp my cylinders...
any guesses on what might be wrong?
Other Details:
At idle i can hear the knocking noise...from 1k-3k i cant but when i go higher than that the noise becomes louder...
Old Dec 25, 2009 | 07:31 PM
Anon51's Avatar
Default Re: Knocking noise on my y8 :(
new years day? and you probably spun a bearing which happens to Y8's due to their fairly crappy oil pumps.
Old Dec 25, 2009 | 07:35 PM
JOS-EM1's Avatar
lol i meant Christmas eve, so does this mean im going to have to replace my oil pump or can i just fix the bearing?
Old Dec 25, 2009 | 07:42 PM
upgrayedd's Avatar
get different engine, is the easiest, cheapest and fastest way to get it running again.
Old Dec 25, 2009 | 07:50 PM
accord2civic2prelude's Avatar
is it a knocking noise or ticking noise?
is it from the head or the block?
Old Dec 25, 2009 | 08:07 PM
JOS-EM1's Avatar
It sounds like a knocking noise, i think its coming form the head...
Old Dec 25, 2009 | 08:31 PM
try checking your valve lashes first. if all those are within spec, you've bent a valve! were you low on oil?
builthatch's Avatar
MiG-21 superfan
if you can find something like a big breaker bar, huge/long screwdriver, etc, put it on different spots on the engine and place/cup your ear to the end. as you move it to different spots, you should be able to discern where the sound is coming from since the sound will be more pronounced as you get near it with the probe end of the tool.
regarding the pumps in the d16y engines, here is a post i made on another forum-
Originally Posted by builthatch
for what it's worth...
i ran a y7 from when i got my old '97 hatch in '98, to somewhere around 01-02. it was built in '99 when it had about 30k on it, with custom 12.5:1 pistons, some sort of resized rod combination and a nitrous setup. i can't remember how many miles i put on it but it was alot because i was going to school and delivering pizza...and just driving everywhere all the time. i never had any issues except with the wrist pin bosses of the pistons, from detonation because it was tuned using some bandaids (MSD retard box for the nitrous, original afc on a chipped, yes, chipped p2e ecu!). The bottom end never had any oiling issues. i'd guess it had ~140k on it when i gave up on it, give or take, with 110k or so of that being built. hard to say because i had the VSS unplugged for a long time because of a harness issue.
then in '02ish, i built a y8. THAT bottom end i ran from '02 to '07, something like 70k @ about 13:1 and ~7500 rpm; the engine had no issues except, again, tuning issues and cracked ring lands a few times on the p29 pistons. the last set of pistons i got tuned with an apexi power fc and it ran perfectly until i parted it out in '07 because i bought a jdm b18c swap.
both times the oil pumps were untouched. if you look at the life of the car, it had 180k on the odo, and there was a LONG stretch during the y7 period where i had the VSS unplugged, so honestly...i had stock y7/y8 oil pumps with stock honda rods and bearings for probably ~220k, and probably 180k of that total mileage was built.
if i was to do it all over again, i'd probably mod the stock oil pump just because it can't hurt. wouldn't shy from an obd2 bottom end though.
Old Dec 25, 2009 | 10:05 PM
randy77's Avatar
rod bearing failure... i had the same problem and fixed it for under $50... took me 3 hours from start to finish ........... GL
Old Dec 25, 2009 | 10:10 PM
JOS-EM1's Avatar
How hard was it to fix the problem?
I dont want to try to do it myself and then end up making it worse...
Can you give a quick summary on how you fixed ur car?
Thank for the help
Old Dec 25, 2009 | 11:17 PM
randy77's Avatar
first you need to put the car on jack stands
then drain the oil
take out the oil pan.. you might need to unbolt the exhaust manifold to get to the other bolts
take out the oil pick up
unbolt the main cradle youre gonna need to hit it with a rubber hammer after you take out all the bolt beacuse the dowel that holds it in... should drop right out
then unbolt the connecting rod cap.. make sure that you have a 17mm socket for your crank youre gonna have to turn it so you can get to the other cylinders
after you unbolt the cap youre gonna have to push the piston upto get to the upper bearing.. sometimes the bearing might be stuck to the crank or it will just fall out or worse it will be in pieces...
check for scarring on the rod cap and the crank if its minimal go ahead and sand it down ith some really fine grit sand paper..... clean after sanding
put in new bearings make sure assemble everything with assembly lube...
put rod cap back on torque to specs.. i believe its 25 ft lbs
to the same on the rest
then put main cradle back on torque to specs.. i believe its 21 lbs on the first step and 38 lbs on the second step..
then assemble everything!!!
goog luck to you.. i also suggest you quit beating on your car
Old Dec 26, 2009 | 07:00 AM
g230sport's Avatar
also, to diagnose which rod is knocking start your car up, and with the hood open, pull one plug wire off at a time. when you find the cylinder thats knocking the noise will go away with the wire off.
also, try and not run it very long... it will only cause more damage.
id get a set of rod bearings. drop the pan, and just put some fresh bearings in it and youd be good.
good luck
Old Dec 26, 2009 | 10:34 AM
94EG8's Avatar
Seagull Management
You can kill a coil doing that, and honestly why bother, if its knocking its going to have to come apart anyway at which point it'll be pretty clear which cylinder it is.
randy77's Avatar
heres the list of parts that i bought
rod bearings $ 32
rtv black silicone.. for your oil pan $7
4 quarts of oil and s2000 oil filter $15
assembly lube $7
all in all you can save this motor if you do it right, but i dont suggest this type of work especially if you are not mechanically inclined to do the work
Old Dec 26, 2009 | 10:45 AM
builthatch's Avatar
MiG-21 superfan
nah, a coil won't be affected by being down one cylinder for a simple test such as that. my question would be- would the fact that the rod is not seeing combustion impact, but still rotating on the crank still yield a sound? i can guess the intensity would change, if anything, when the proper wire is pulled.
anyway, to continue about your post, if you can isolate it to one rod, that certainly would be ideal, since it's much better to take down one rod, vs. unnecessarily undoing 4 rod caps. but honestly, if i were him, since it's already apart i'd probably check the condition of all of them, so i can see THAT point.
Old Dec 26, 2009 | 11:10 AM
JOS-EM1's Avatar
Well I've been searching for a mechanic that works the day after Christmas and theirs none! lmao...
Since this is my only car, should i take the bus to work today!?
Old Dec 26, 2009 | 11:37 AM
builthatch's Avatar
MiG-21 superfan
haha, you do what you gotta do, but get to work! haha
anyway, yeah if i were you i'd look into getting in touch with a reputable performance honda/import shop in the area, as opposed to anyone else.
you live in the LA area i assume so that shouldn't be hard!
maybe call exospeed and see who Wil recommends- (661) 775-1963
Old Dec 26, 2009 | 11:43 AM
slomofo's Avatar
GDD Member
Easiest way to diagnose rod knock.
Drain your oil and put in 20w50, if the noise goes away, it's a rod knock.
Old Dec 26, 2009 | 02:00 PM
JOS-EM1's Avatar
Well Just finished Changing my oil and adding a bottle of Lucas to see if crappy oil was my problem but it just managed to weaken the knock but not completely take it away, im pretty sure im going to have to get my rod bearings replaced witch im sure will be a pain in the @$$
any guesses on how much a mechanic might charge me to get the rods replaced?
any other suggestions???
Thanks for all the help :D
Old Dec 26, 2009 | 03:20 PM
mikej94civex's Avatar
not sure if this is your problem or not, but try running a higher octane
fuel, premium even maybe, higher octane fuel is meant to reduce "engine knock"
so try that for a full tank or 2...
oh, and if it's just an annoying tick it's a honda lol.
Old Dec 26, 2009 | 03:52 PM
slomofo's Avatar
GDD Member
Pull your oil pan off, pull the main and rod caps, whip out your mic and start measuring. If it's within spec, you can replace the bearings on the car.
He has a rod knock, not detonation.
Old Dec 26, 2009 | 10:53 PM
roycivic92's Avatar
just get a used sohc block or a junk yard motor cheaper and faster
Old Dec 26, 2009 | 11:11 PM
Arthas's Avatar
Is it really that easy to change out the bearings on the rods? You guys make it sound like its cake. The closets ive gotten down there is dropping the pan when I had to change my oil pan gasket.
Old Dec 27, 2009 | 11:51 AM
slomofo's Avatar
GDD Member
Umm yeah dude, it's pretty easy.
Drop the pan.
Remove the oil pickup tube.
Remove windage tray.
There you go, you're now staring at 8 bolts that hold on four rod caps.
Old Dec 28, 2009 | 10:51 PM
JOS-EM1's Avatar
Well I would just like to thank everyone from honda tech for helping me figure out what was wrong with my car :D
Well I took my car to Demon Workz Located in Garden Grove
(Props to Bernard for all the help) and they confermed what you guys thought the problem was.
It was a Rod bearing that was toast Due to running low on oil and driving on it for a day...
"My Bad" but he is getting it done as we speak and im gonna pick up my baby 2maro :D
Moral of the story: Stop Beating on my Baby! and always check that oil...
Had to learn the hard way like i said "another lesson learned"
But anyways Thanks To all for the help :D
JOS-EM1
