bad int shaft?
Old Dec 25, 2009 | 05:00 PM
blasterman87's Avatar
Default bad int shaft?
89 civicsi, b16 swap using s1 integra tranny and int shaft. i have a hell of a grinding noise coming from drivers side front, its worse when i turn the wheel and its not the brakes. and the axles have around 2k miles on them, the only thing i didnt replace is the int shaft, is this something that goes bad often and could this be my problem? or could i just have a crappy axle? and also is there fluid inside the int shaft? how do the bearings inside there get lubed? or do they not? thanks
Old Dec 25, 2009 | 05:13 PM
B16-CRX's Avatar
Default Re: bad int shaft?
The int. shaft doesnt have grease in it. Its basically a sealed large bearing. Have you checked your hub bearings? They can make a grinding noise. Jack up the car and spin the wheels. If it is bad enough you will be able to feel where the grinding is coming from.
Old Dec 25, 2009 | 06:10 PM
bearings are good, its really loud when i give it throttle/excelirate, and when i turn its even worse.
Hawaiianhonda
Oct 17, 2015 10:57 AM
RTW DC2R
Jul 11, 2012 07:36 AM
xtreme-customz
Nov 29, 2010 05:26 PM
TylerB
Transmission & Drivetrain
May 6, 2009 06:43 PM
