Question for someone with an 89 OEM Owners manual
Old Dec 25, 2009 | 03:42 PM
wakaranai's Avatar
Default Question for someone with an 89 OEM Owners manual
I want to get this clarified once and for all. According to the "Honda master weight list" floating around the web, the weight for an 89 Si is 2161lbs and the 90 is supposed to weight 2291lbs due to the bumpers/supports and doors.
However, an experienced national champion autocrosser who has exclusively raced ED7's, said the weight difference should be ~40lbs.
If you have an 89 Honda Owner's manual can you please check and see if the 89's (2162lbs) weight is correct?
Anyone know if the weights listed include standard options only?
Thanks in advance!
Old Dec 25, 2009 | 04:10 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Question for someone with an 89 OEM Owners manual
http://www.superhonda.com/forum/f86/...-honda-198926/
Old Dec 25, 2009 | 04:29 PM
wakaranai's Avatar
I've seen that list many times.
I am trying to verify the accuracy of what is listed on it.
Old Dec 25, 2009 | 04:43 PM
xpwex's Avatar
Here you go foo
sorry for smallness
Curb Weight
Si 2209lbs 1,002kg with AC
Si 2161lbs 980kg with out AC
Old Dec 25, 2009 | 04:45 PM
xpwex's Avatar
I just noticed Under 3rd section Engine it says Fuel required Unleaded grade gasoline with 91 research octane number or higher lol
Old Dec 25, 2009 | 05:01 PM
wakaranai's Avatar
Sweet. Thanks!
Just waiting for a friend to check his 91 owners manual lol. At this point it looks like the "Master List" is correct...
HoopR
Jun 27, 2021 08:03 AM
91CrxMann
30
Sep 10, 2010 02:56 PM
89civich22
Dec 13, 2005 08:18 PM
AphexMatt
Aug 7, 2004 02:53 PM
scorched0
Jan 8, 2004 03:48 AM
