b16 Vortech SuperCharger (Owner's Thread)
Old Dec 25, 2009 | 03:16 PM
kw8z3boi's Avatar
Default b16 Vortech SuperCharger (Owner's Thread)
Just wondering if anybody on here has a B16 Vortech SuperCharger? Just gotta few question to ask
Old Dec 27, 2009 | 12:21 AM
kw8z3boi's Avatar
Default Re: b16 Vortech SuperCharger (Owner's Thread)
damn no one have this kit anymore
Old Dec 27, 2009 | 08:30 AM
boostek9's Avatar
i had this kit on my 00 si, very dissapointing. i sold the car with the kit for 7k
Old Dec 27, 2009 | 05:23 PM
kw8z3boi's Avatar
oh damn, what made you so disappointed about it? Did you remember where you plug your air sensor? Also where does the hose goes to, the one that you suppose to mount the MAP on top?
Old Dec 27, 2009 | 07:30 PM
boostek9's Avatar
did not make much power, turbo is much better and less expensive
air temp sensor goes in plastic pipe prior to the blower, you need to extend the wiring
there is no hose going to the map sensor check valve
Old Dec 27, 2009 | 10:37 PM
kw8z3boi's Avatar
oh okay. If you still have pics of the set up, you mind sending me it? thanks
Old Dec 28, 2009 | 12:11 AM
boxeocampeon's Avatar
i like vortech cus it works with a bov i believe but i heard jackson is much more reliable but vortech can boost more
Old Dec 28, 2009 | 12:18 AM
kw8z3boi's Avatar
from what I know, Jackson is great to low end, Vortech is more of like mid/high end. Plus vortech have more potential.
Old Dec 28, 2009 | 02:19 AM
boostedcivicsir's Avatar
Mr. Badwrench
vortech is basically a poorly sized belt driven turbo that makes peak power at peak rpm. thats the downfall of that kit. the jackson being a pdb, isnt as bad.
a properly sized turbo will outperform the vortech by a lot.
it isnt a bad kit. just not a very effecient one.
Old Dec 28, 2009 | 03:15 AM
boostek9's Avatar
here is the car i sold
http://hondamarketplace.com/showthread.php?t=2575629
Old Jan 1, 2010 | 10:06 PM
kw8z3boi's Avatar
Wow, nice. Did you BOV even work? because mine doesn't seem to work at all, I was think advance to timing just to see if it going to work. Since the BOV is not workin, I'm guessing there's something wrong
Old Jan 2, 2010 | 08:09 AM
boostek9's Avatar
my BOV worked fine, it actually should be open when at idle, since the blower makes boost at idle. get a new BOV if yours isnt working
Old Jan 3, 2010 | 01:42 AM
kw8z3boi's Avatar
i think i know what's the problem is. I never hook it up to the Fuel pressure regulator.
Old Jan 3, 2010 | 06:11 AM
boostek9's Avatar
thats not where i would hook it up
get you vaccuum/boost feed from the larger port on the front side of the intake manifold
Old Jan 9, 2010 | 05:15 AM
kw8z3boi's Avatar
let's say on this pic, i would hook it up to the port under the SKUNK2 plate right?
Old Jan 9, 2010 | 09:01 AM
boostek9's Avatar
yes, T it into the line from the manifold to the PCV fitting
Old Jan 28, 2010 | 10:54 AM
kw8z3boi's Avatar
anyone know where I'm suppose to connect the hose where on top VALVE COVER to?
Old Jan 28, 2010 | 06:40 PM
1.5Slowmatic's Avatar
put a filter over it or run a catch can.
Old Jan 29, 2010 | 01:53 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
lol at the "dohc vortech" stickers thats pretty good.
Old Jan 29, 2010 | 03:29 AM
crashsvg's Avatar
i had one was on a b18c doh..same set up any ways..make 253whp @9psi..what was it u wanted to know?
Old Jan 29, 2010 | 03:18 PM
kw8z3boi's Avatar
1. Are there several hose that I can hook up the BOV to or the best one is the fuel press regulator? A few people said that I can also hook it up to where the hose on the Intake Manifold for the Cruise Control (I took out my cruise control box), instead of using a T-Fiting on the fuel pressure regulator.
2. Is true that is risky to run a aftercool intake box if I don't do my internals? A friend said that I can blow my internal is I don't.
3. Do I really need to install the Vortech FMU? I'm just asking because mine is messing a few parts. Smog shop told me that I should be find upgrading the stock fuel pump to Wabro 255.
4. What gauges do you recommend getting?
Old Jan 29, 2010 | 04:36 PM
crashsvg's Avatar
ok..ama answer to the best of my knowledge.
1.any vacuum line that detects boost can be used to signal the blow off..
2. i dont really understand the question..but a after cooler (water to air) acts like a inter-cooler. it cools the air before it goes into the intake manifold.depending on boost level a after cooler is needed to help lower chances of detonation...regardless of built or stock engine anything above 10 psi with out proper cooling will blow your engine..if you are running 7 psi you would be safe but higher than that i recommend you get a after cooler.
3.yes u need to..fmu raises the fuel pressure as u boost more..with out it you will blow your moto...the only way you could remove it is if u install something to help control the fuel.management or a super fc or something.. and yes u need to upgrade your stock fuel pump.
4.its up to you.. i just put in a boost and oil pressure gauge
rem get your engine tune or else the car would never run right...
Vspronk
Apr 22, 2016 11:27 AM
hondatuner020
Jan 6, 2008 07:33 PM
crxsleeper210
Oct 10, 2007 09:28 AM
CrazyModGSR
Apr 11, 2006 03:21 AM
teler86
Dec 18, 2004 10:50 AM
