jdm itr bulb cracked in headlight
Old Dec 25, 2009 | 12:52 PM
froogle29's Avatar
Default jdm itr bulb cracked in headlight
I have a cracked fog light bulb in the my jdm front conversion and it's just dangling around in there. Anyone have any idea on how to take it out? Thanks
Old Dec 25, 2009 | 02:09 PM
TypeRMOBBiN209's Avatar
Default Re: jdm itr bulb cracked in headlight
take the headlight apart?
Old Dec 25, 2009 | 04:58 PM
froogle29's Avatar
would that require putting the headlight in the oven or how would I be able to take it apart? thanks and merry christmas
Old Dec 25, 2009 | 05:03 PM
YellowKahuna's Avatar
should have used OEM spec bulbs, next time
Old Dec 25, 2009 | 05:10 PM
exotik4doorcivic's Avatar
the yellow bulbs are oem spec bulbs
can you take the cover from behind pull the rest of the bulb from the socket, and try shaking the rest out?
Old Dec 25, 2009 | 05:13 PM
bakertime's Avatar
vacuum with a small attachment?
Old Dec 27, 2009 | 02:52 PM
SOHCunderdog's Avatar
Same thing wrong with mine. You might really have to put that headlight in the oven to heat up the seal and take apart.
Havent gotten around to mine as yet.
Old Dec 28, 2009 | 06:20 PM
734's Avatar
734
This is what I did when my bulb busted. I used a .5inch rubber hose and taped it the vacuum attachment. It worked well...
Evil Ryu
Sep 8, 2008 12:19 AM
NAturalDC2
May 10, 2004 06:41 PM
Beave0101
Mar 7, 2003 11:38 AM
intevic2010
Oct 16, 2001 09:34 PM
