reverse lights not working...
Old Dec 25, 2009 | 11:28 AM
skipbudlong's Avatar
Default reverse lights not working...
ed7 wit a b16 obd-0. I have the wires, yellow and green. Just need to know where they go connected. Any help?
Old Dec 25, 2009 | 01:12 PM
crx_si-r's Avatar
Default Re: reverse lights not working...
They should plug right into your harness. Is your harness still complete? If it's connected and they still don't work check your fuses. If they are good then check your bulb. Last option would be the switch.
Old Dec 25, 2009 | 03:07 PM
Je2RiT's Avatar
yea your plugs should come from the same area of the wiring loom as the o2 sensors.
and your plugs for the switch should be near the clutch arm (near the front mount)
Old Dec 25, 2009 | 03:10 PM
THe wires are sliced. Where exactly in the harness. Have pictures? ANyone?
Old Dec 25, 2009 | 04:43 PM
Je2RiT's Avatar
ok, so I ran out to my car an took a pic with my phone.. lol..
Sorry for the somewhat poor quality.
Old Dec 25, 2009 | 09:26 PM
Ill see what is up with that tomorrow. What is it connected to?
Old Dec 25, 2009 | 10:55 PM
My_EFsedan's Avatar
:facepalm: its connected on the trans. the yellow/green from the harness goes there.
Old Dec 26, 2009 | 06:58 AM
BrayzieEF9's Avatar
Hi not to thread jack but i got somewhat the same problem except my reverse lights are on when i'm in neutral or in gear.it started happening when i put a new clutch in.does the car have to be in reverse when you connect the wires or is my switches bad?
four wheel geek
Honda CR-V & Element
Jan 16, 2019 04:56 PM
werteg
Jan 4, 2011 08:36 PM
JdmB18C667
Jan 24, 2009 09:37 AM
dpine
Sep 27, 2005 05:42 PM
