92-93/94-95 glove box
I just swapped my 92 dash out of my civic into my 95 civic. It appears the glove box is different between the years?? I assume this is because of the pass airbag. (Yes, the plastic inside the dash did break on install, this should've been my first clue..)
Will a 94/95 glove box fit my 92 dashboard? I'd prefer not removing my dash again.
Anthony
Anthony
Anthony
Anthony
What about removing the metal frame? This is the "airbag ****" he's referring to.... check a parts diagram and note the p/s dash parts that are different. Remove the ones related to the airbag and your 92 box will fit again.
Argh, F YOU HONDA. I guess that's what I'll do... but not now. I'll pull the dash out some other time for that.. Or, I can just take a grinder to it or something.
I'm sure those latches the glovebox uses are similar to like, the door latches you could buy at Home Depot right? Probably 1" or something. I bought my car without a glovebox, and bought one from the junkyard a while back but still haven't installed it. But now that I know for sure it's gonna fit, I wanna get it installed ASAP.
crls057
Mar 26, 2012 12:18 PM
90civichb
Feb 19, 2005 09:22 PM
92SiB18C1
Nov 15, 2002 09:27 AM
