AWD CRX?>?
what are you using? i heard of the wago but im skeptical if the drive train could handle the HP that its putting down w/o snapping axles n driveshafts n such seeing how the wago wasent made 2 put much 2 the ground
I had a awd wago for a long time and it finally was time to retire the old girl. Out came the motor and driveline, found an out of state crx with absolutely no rust at all and now Im starting the conversion. Im gonna be running the d16 out of the wagon, gonna build it up so it can handle the boost and Im aimin for 350 hp. We will find out how the wago tranny holds up to the abuse
I'm sure the drive shaft shop could help with those issues. Maybe gearspeed or Mfactory makes a good gearset for those transmissions??
nice nice well keep me posted on your progress and problems ha cause im sure there will be a good amount. so could i use a B series i know they make a D to B conversion but i dont think a B to D? my b16 is freshly rebuilt n not ready 2 take it out quite yet.............unless i were 2 pick something else 2 put it in which doesnt sound like such a bad idea either
https://honda-tech.com/forums/appearance-build-threads-122/just-another-b16-swap-viewing-pleasure-pics-2076976/
u said u got a b series engine. if you go wagon, im sure you will have to go back to d series. if u wanna keep that b series i think you should go with the crv awd setup. either way both would be fun as hell i bet. whatever you decide good luck and a build thread is always interesting
and id like 2 someday make it AWD is this a lost hope or very much possible???
