AWD Civic
Old Jun 24, 2003 | 01:19 PM
Tinker219's Avatar
Default AWD Civic
Ive been ******* around with the idea of doing the CRV drivetrain thing for quite some time. Now Im serious, and it WILL be done. I know theres a CRX on here thats had the conversion done, but what else is there?
I plan on making an entire custom rear assembly to aide in ground clearance/stiffness/strength. Now all I need is a totalled 5 spd AWD CRV, and Im golden...
Anyone want to share some thoughts?
Old Jun 24, 2003 | 01:23 PM
b18bturbo's Avatar
Default Re: AWD Civic (Tinker219)
why dont you just get an awd civic they made them back in the day
Old Jun 24, 2003 | 01:31 PM
Tinker219's Avatar
Default Re: AWD Civic (b18bturbo)
Ive had a wagon before, I dont think Id be caught dead in one. But thatd be a HELL of a sleeper. 500whp in one of those, just gotta convert the driveshaft to accept the B20 trans...VERY little modification.
But whats the fun in that?
The drivetrain will be going in this car(which will soon be midori green):
Old Jun 24, 2003 | 01:32 PM
b18bturbo's Avatar
you can probably find the drivetrain at any local junkyard good place to start is honda specific one.s
I am sure the crv system wont be able to handle the 500hp you plan to put down. I would take bet probably 300 hp 300 ft lbs is about the limit. the shaft is so puny as well as the rear diff
Old Jun 24, 2003 | 01:34 PM
Tinker219's Avatar
they want over $10k for the ****...and there arent any 5speeds. I could pry go to the dealer and get better prices then that...
anyone got a 5spd awd b20 trans laying around from Jap-land or something???
the diffs are about a 70-30 split. So... 500X.7=350 at the front. 150 at the rear. As long as I dont do 9k rpm launches, I should probably be ok...
Old Jun 24, 2003 | 01:35 PM
CivicSoul's Avatar
I have thought about that idea and there is no reason why it wouldnt work. The weak link, I have heard, is the drivetrain. The easiest way to do it would to be to actually use the crv and modify it. (slam it, with full suspension, tighten up the chasis and chop the top)! Then it is a matter of motor swaps and beafing up. It would be a f-ing nice day when I see an all wheel drive CRV with a built motor, as low as a civic, missing three inches of head room, and stiff as a brick! If anyone can do it, you have the means and the ability to do it. And I will volunteer to be your rally navigator
Old Jun 24, 2003 | 01:36 PM
mos's Avatar
mos
500 hp? What are you going to do to the CRV drivetrain to make it accept that much power? I wouldn't think there would be many honda parts left after you do that.
Sounds like fun tho.
Old Jun 24, 2003 | 01:37 PM
metal-x's Avatar
Default Re: AWD Civic (mos)
what you want is a RWD civic
Tinker219's Avatar
Im just theorizing here. The main reason Im doing this is is for wet weather, and VERY possibly, some rally events. YES the car will be raised up
Old Jun 24, 2003 | 01:39 PM
Tinker219's Avatar
Default Re: AWD Civic (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">what you want is a RWD civic </TD></TR></TABLE>
why dont I go with a 427 hemi and blower while Im at it. Should be able to get it done in a weekend
I want the awd because Ive only seen one other car with it, and that was the crx...
Old Jun 24, 2003 | 02:14 PM
sutrusu's Avatar
have you seen how THIN the shafts are that power the rear wheels?!!!
Old Jun 24, 2003 | 02:18 PM
Tinker219's Avatar
Default Re: AWD Civic (sutrusu)
yep. no reason I shouldnt be able to retro something else on there. **** it, ill just run those. They only see 30% of the power anyway, hence why they are so much smaller than the front axles...
I want to be able to roll from 25mph, and not spin the tires till 100mph, or do some drifing once the snow flys up here. Full throtlle launches on dry pavement are too loud and noisy, and yes they break ****. Im not doing this for the initial launch, but more for staying moving once I get moving...
Old Jun 24, 2003 | 02:35 PM
Garrett's Avatar
Look at this
http://public.fotki.com/morgie...turbo/
Old Jun 24, 2003 | 02:47 PM
Tinker219's Avatar
Default Re: (Garrett)
ya thats the one i mentioned above. Those rear axles look scary being choppped and welded like they are. I have access to custom axles, so if need-be, ill just get some beefier ones made. I think for what Im doing, they wont be needed...
Old Jun 24, 2003 | 03:32 PM
psileepR's Avatar
New User
Default Re: (Tinker219)
wow that crx is sick... gl on your civic buildup.. awd sounds like fun
Old Jun 24, 2003 | 03:47 PM
lazerus's Avatar
Default Re: (Civtek)
that rear diff will probably crack like an egg under boost. maybe you can swap in a diff from something else?
Old Jun 24, 2003 | 04:08 PM
Sprayteg's Avatar
I seen this awd crx make 1.7 60ft all day long with no trouble (b18c/6psi), he's using civic awd rear drivetrain with the crv trans.
Old Jun 24, 2003 | 05:03 PM
NuclearB18B's Avatar
Default Re: AWD Civic (blackLS-T)
you might as well just buy a CRV...
Old Jun 24, 2003 | 08:56 PM
sporkcrx's Avatar
Default Re: AWD Civic (ha illuminato un)
I thought that all of the awd crv's were automatics?
Old Jun 24, 2003 | 08:59 PM
Accord94DX's Avatar
Default Re: AWD Civic (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">I thought that all of the awd crv's were automatics? </TD></TR></TABLE>
nope.
Old Jun 24, 2003 | 09:44 PM
liam821's Avatar
25 Year Member
Default Re: AWD Civic (Accord94DX)
I dont think the rear axles, diff, transfer case, would hold up to a 500hp turbo honda.
Just last weekend i was out with my friend. He has a ~400-450whp 1st gen eclipse GSX. We were trying to figure out why it was overheating. We were running around on 26-28psi on race gas. We did one "little" test launch and blewup the rear end (he has a 3 bolt rear though..the weak one...4 bolt search as started).
My point is just like the DSM world, the CRV drive train wasnt designed for that much power in mind. Im sure it will take a ton of abuse...but you might take after the dsm kids with replacing tranny parts all the time.
liam
Old Jun 24, 2003 | 09:48 PM
lazerus's Avatar
Default Re: AWD Civic (liam821)
4 bolt rear ends can take the power... 3 bolts can take alot it too, if you are a lightened race car.
the key is to keep the weight way down, then they wont be prone to breakages quite as much. but of course, there are limits.
Old Jun 24, 2003 | 10:08 PM
Type-GS-R-Turbo's Avatar
Where do they make AWD Manual CR-Vs? are they even available in america? That's crazy. I'm still waiting for the issue of Honda Tuning with the AWD Type R.
Old Jun 24, 2003 | 10:41 PM
shortyz's Avatar
Default Re: (Type-GS-R-Turbo)
now i can see that is dying to see 300hp
is there any way to weld a CRV transfer housing so u dont get only 20%.??
Old Jun 25, 2003 | 12:45 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (shortyz)
waste of $$$$ the CRV trannies are weak!! someone down here did it and nothing but issues. you break something and you have to wait months for parts!!! if you want awd by a subaru!!!
