TODA Spec B idle problems.....
Old Sep 3, 2002 | 12:23 PM
CStyles45's Avatar
Default TODA Spec B idle problems.....
Hey everyone. I gotta question and I could use anyone's help on it. I just got my ITR back with installed Spec B cams, TODA cam gears, valve springs, tit. retainers, mugen head gasket and PE timing belt. Right now, we have the timing set at 0,0; but there's a problem, she won't idle at all. . We're kinda stumped as to what it may be at this time. I still have a VAFC that needs installed, I know that can take care of the idle normally by leaning it out and what not but to my understanding, the TODA B's were supposed to idle like stock at 0,0 timing. Our only make due solution at the moment is to tighten up the throttle cable so it'll idle at 1000 RPMs. Does anyone have any insight as to what it may be or ways to solve the problem? Any help would be GREATLY appriciated. Thanks a lot. I know I can count on you guys!! BTW, for the car being totally untuned, I"m quite happy with my cams and can't wait till I get her on the dyno.
Old Sep 3, 2002 | 12:24 PM
B18CXr's Avatar
Default Re: TODA Spec B idle problems..... (CStyles45)
you need electronic fuel control
Old Sep 3, 2002 | 12:26 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
I know my car idle'd like crap when I had my cams installed and set @ 0. It sounded like it wanted to shut off but didin't. I had to take 24 % fuel with the v-AFC @ idle for it to idle almost perfect.
Old Sep 3, 2002 | 12:27 PM
BlueR's Avatar
Default Re: TODA Spec B idle problems..... (Apex i ITR)
i'm at -25 at 1k rpm
Old Sep 3, 2002 | 12:33 PM
Black R's Avatar
25 Year Member
Default Re: TODA Spec B idle problems..... (BlueR)
correctamundo! I'm at -50 there... Damn overlap!
Old Sep 3, 2002 | 12:49 PM
Big Phat R's Avatar
Install it.
You can't run B's on a stock ECU.
Old Sep 3, 2002 | 12:55 PM
BlueR's Avatar
Default Re: TODA Spec B idle problems..... (Big Phat R)
Install it.
you did all that and didn't install the vafc...
its the easiest part of your entire project...
Old Sep 3, 2002 | 02:56 PM
StinkyTofu's Avatar
Adjust your timing. I had the same problem with my GSR, but i had to run it with 21 degrees. Have your car tuned soon!
edit: I've been running on stock gsr ecu + vafc for the past half year and it works fine. However, i suggest getting a hondata in the future to fine tune it.
[Modified by StinkyTofu, 3:57 PM 9/3/2002]
Old Sep 3, 2002 | 03:00 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: TODA Spec B idle problems..... (B18CXr)
Put that V-AFC in tonight
Old Sep 3, 2002 | 03:03 PM
Smitdog's Avatar
Default Re: TODA Spec B idle problems..... (Splat)
Old Sep 3, 2002 | 03:07 PM
CStyles45's Avatar
Default Re: TODA Spec B idle problems..... (Smitdog)
Alright, cool, at least I know it's because of that now, phew. The only reason why it isn't in now is because we just didn't have time to get to it( ) We also wanted to make sure that the cams and everything was ok before messin w/ the VAFC. But don't worry, it's going in tomorrow afternoon. Thanks for the help everyone.
Old Sep 3, 2002 | 04:48 PM
Darin D.'s Avatar
all you need to do is open up the idle air screw a lot. With the cams at 0,0 it will idle like stock.
Old Sep 4, 2002 | 07:53 AM
CHEETAH's Avatar
Default Re: TODA Spec B idle problems..... (Willis)
actually the screw doesnt help, what hels is the little 8mm nut wiht hex sxrew that raises throttle plate, screw it up a little to hold butterfly open and it works like stock. If you have a vafc then just lean out at idle about -20% does it good.
greg
Old Sep 4, 2002 | 08:08 AM
PMTypeR's Avatar
Default Re: TODA Spec B idle problems..... (CHEETAH)
VAFC helps but you still may gonna get a different ECU
EF_LSVtec
12
Jun 28, 2003 05:29 PM
TriK
May 12, 2003 04:49 AM
StinkyTofu
Apr 21, 2002 01:22 PM
StinkyTofu
Apr 20, 2002 11:22 PM
TaboR
Apr 9, 2002 12:52 PM
