90 b16 tranny doesnt match up with 01gsr?
Old Dec 24, 2009 | 11:55 AM
tony7626's Avatar
Default 90 b16 tranny doesnt match up with 01gsr?
Swapping in my gsr, but now my friend said i cant use the j1 b16 trans on the gsr because some shaft is different? the guy i bought the car off said he thinks the motor was from a 90 but he wasnt sure, any way i can check on that? tranny still has serial on it. does anyone know what part i need to change out or if i can even use this tranny, as far as i knew i thought all B series were compatible but i searched and found posts saying up to 91 there was a difference? i have searched and i cant find what part i need to change so any advice would be awesome.
Old Dec 24, 2009 | 01:22 PM
ryanevansoh's Avatar
Default Re: 90 b16 tranny doesnt match up with 01gsr?
b series motors are all compatible with b series tranny. the 90-91 clutch have a different spline count that the 92-93 though
Old Dec 24, 2009 | 01:23 PM
sh!ft's Avatar
Who the fack changed my title?!
obd0 b16 has like 22 or 23 teeth on the mainshaft vs 24 on obd1+ models
Old Dec 24, 2009 | 01:45 PM
tony7626's Avatar
so what do i need to do!? can i make it work or do i need a new tranny
Old Dec 24, 2009 | 01:48 PM
well if you have a clutch for a 90-91 then it will bolt up and work
Old Dec 24, 2009 | 02:33 PM
sh!ft's Avatar
first n foremost, you need to take out the trans and count the number of teeth n the shaft. then do some research and find out what trans. had that many teeth in the early 90's and then shoot for the clutch setup for that trans, put it on bolt the trans back up and break it in.
Old Dec 24, 2009 | 02:54 PM
Deetz's Avatar
Crazy Honda Guy
this is correct!!
Old Dec 24, 2009 | 03:53 PM
crx_si-r's Avatar
yup, everyone on here is correct! your transmission doesnt actually connect to the motor except for the actual bolts and the shaft. which only touches the pilot bearing. all that matters is that the clutch matches your transmission.
now go school your buddy that said it wont work.
Old Dec 25, 2009 | 07:52 AM
tony7626's Avatar
well that works out perfect because the motor that is currently in there is my b16 and i have the clutch setup from that, so i could just transfer everything over with no issues? when i picked up the gsr he left the old clutch on it.
Da4yoA$$
Feb 7, 2007 11:19 PM
stefanne3
Jan 25, 2006 05:02 PM
EFin' Kyle
Aug 2, 2004 10:56 AM
