Distributor and boost questions about putting Z6 or Y8 head on Y5 engine
Here's the low down...........
Its a D16Y5 ( vtec-e ) w/manual trans.
I dont want to convert to OBD1.
I have a D16Z6 head ( free find ) to put on.
Question #1.......
Can i use my D16Y5 ( OBD2 ) distributor on the D16Z6 ( OBD1 ) head without converting to OBD1?
Question # 2........
Would i be better off putting on a D16Y8 head on my D16Y5 block?
Question #3.........
Is the D16Y5 block good for boost?
(i heard that with the stock internals it can handle lots of boost)
Question #1.......
Im really glad no one responded to this thread.
I found out (with a little research) that the D16Y5 motor in my car is not the original motor. The D16Y5 in fact only comes in the 96-98 HX hatch back model, and not the coupe. So i guess i answered my own question about my build.
I will get rid of the motor and drop in a mini-me.
Prolly turbo it.
Prolly turbo it.
Prolly turbo it.
Prolly turbo it.
There is no HX hatch. Its a Coupe. It only comes in a Coupe.
Y8 heads are bad.
It can handle about 200-220WHP max on a stock block.
A z6 head is better if you are going to boost it.
Getting rid of the motor and dropping a mini-me? A mini-me is just changing the head on your current engine.
No.
Y8 heads are bad.
Y8 heads are bad.
And thanks to all for the advise.
its easier to put a d16y8 head on since its obd2
everyone seems to think the d16z6 head is a better option but i think they are about the same.
its the blocks on the y8's that blow (crank, oil pump, etc)
however if you plan to boost. obd1 is easier to tune.
so if you ask me its kind of a toss up
If you are staying all motor then put a Y8 head. If you are going FI then do a Z6. Or if you can find a Cam for the Y5, then thats even better, since the Y5 head has roller rockers.
Well i took a few snap shots of the program we use at work.
( this is where i got the info about the motor from. Hope its clear enough )
this is the program. Shopkey ( i searched 1996 honda civic HX hatchback and this is he results of engine identification)
this is what it tells me.( all info is per honda motor corp.)
i probably will slap on a Y8 head and work with that.
Just till i get a B16/B18.
If you boost your D series you can easily make more power than you would have with a B series swap.
the Y8 head has a square/rectangle combustion chamber, and it is shorter, which increases compression, and since its small and irregularly shaped its bad for FI.
thanks for the info.
I tend to believe honda enthusiest at times.
Isnt the hatch a CX and the coupe HX?
Anyhow, so if i boost a sohc i can get more HP than a dohc?
(n/a or boosted dohc?)
The HX was a coupe only and was available in 96-99 with the commonly referred too "vtec-E" and is the successor to the VX models of the 92-95 era, and the HF of the 88-91 era. I know the head featured roller rockers, but im not too aware off the performance aspects of it though, so in my opinion a decent SOHC build would be the typical D16 block with pistons, a regular MLS head gasket and a decently worked head, and a t3/t4, we did one here in Colorado that ran 12's and was a beast on the street Also a relatively cheap build as well.
The only distributor that will work on a Z6 is an OBD1, SOHC D series VTEC distributor ie JDM D15b, OBD1 ZC VTEC, D15Z1 (VX). Other distributors will seem like they bolt up but they wont allow enough adjustment to time correctly.
Y5 head on a better block (ie Y8) with a VTEC trans and with the Y5 ECU or a tuned ECU rips quite nicely. I much prefer it to any other SOHC.
You can have more power than a Boosted DOHC aswell, but in the world of boost it depends on how much boost you are running, how big your turbo is, and who tuned it.
But you can build and boost your D series for the price of a GSR swap. And make more power than a GSR (you could have more than 2x the power, depending on turbo, amount of boost, and tune). Thats what I did, my whole build cost around $3600, and thats including swapping the car to manual and a freshly built block, weighted, balanced, honed, decked, tanked, everything. I don't regret my build at all, if I could go back and make a different choice, I would take the same route.
yes the hatch is CX and the coupe is HX. But the 96-00 CX hatch is powered by a Y7. The HX Model is the only one with a Y5.
Thanks again. OBD1 here i come.
hey sorry i havent answered back yet, i assume you have your answer by now but mine does not have sunroof but does have power windows and locks no cruise control also it has black moldings and mirrors just like the dx
im not sure if sunroof was an option. But the HX has about half the features of the EX. My friend had one.
Installing my gripforce f1 stage 2 clutch today.
Thanks to all of you who post here. Your info is greatly appreciated.
Happy new year btw. I will post pics of the clutch swap. Just for the hell of it.
It is in fact a Y5.
However i have a couple of questions.
1. I have a b000 trans but the 3rd and up gears suck. Why is that?
2. Where can i get an aftermarket cam for this head?
i dont think anyone actually makes cams for the Y5 head, but changing it to a regular VTEC cam would negate anything you got from having a Y5, which is good low end TQ and gas mileage.
(BOOO) trans for sohc's are usuallly ex or vtec models but if you said you had a y5 its a economical motor and trans so you got a super long ratio trans. Port the head until its bigger than a normal y8 head and it will flow the same was a y8 or better depending on how much you port and get a stage 1 cam with your roller rockers on the y5 power will be good till 8-9k - less friction. {according to a guy at crower}. port you oil pump and it will compensate for the 1 oiling hole in the crank. all y-series have bad oil pump and bad crank.( 1 oiling hole). or you could go with a a6/z6 crank and oil pump but it will negate your dipstick. these cranks have 2 oiling holes much better for lube... get a obd2a <-> obd1 conversion harness and get a chipped p28. dont use a stock p28 timing is 16 y-series timing is 12 degrees so you will be off half a tooth of timing from crank or actual ecu timing.
