HELP! some sort of belt/ whine noise when decel (happens very very rare but only sinc
Old Dec 24, 2009 | 10:19 AM
DC2many's Avatar
Default HELP! some sort of belt/ whine noise when decel (happens very very rare but only sinc
95 gsr
ok heres the run down
i went for a touge drive yesterday and scraped and sparked a bit
hit a few bumps
ok now last night i get a WHINE or some sort of belt noise on decel at low speeds around 40
it happened again this morning but this time around 30 coasting in gear to a light
anyone help please?
thanks
i see no leaks
Old Dec 30, 2009 | 09:16 PM
DC2many's Avatar
Default Re: HELP! some sort of belt/ whine noise when decel (happens very very rare but only
BUMP i think something is seriously wrong, it comes from the front right side randomly upon decel
VIDEO COMING UP, CAN'T REALLY HEAR IT DUE TO BAD RECORDING BUT I MARKED THE TIMES YOU HEAR THE WHINE ON THE DESCRIPTION. sound also sounds like a goose bov call, also attached in video. (not my subbie someone else)
http://www.youtube.com/watch?v=joKhiaeocqQ
Old Dec 31, 2009 | 12:20 PM
DC2many's Avatar
bummppppp
Old Dec 31, 2009 | 12:29 PM
DJYoshaBYD's Avatar
is your car automatic or stick?
How hard did you scrape?
Did you get under the car and PHYSICALLY check for damage? Scratches, gouges, dents etc.?
When you say front-right side, do you mean front driver side, or front passenger?
Old Dec 31, 2009 | 12:44 PM
DC2many's Avatar
manual you can tell from the vid and front right is FRONT right passenger side.
i dunno ow hard i scrape id rather pay attention to not crashing but behind me say they saw sparks quite often.
and i don't have any jacks atm to check under the car
Old Dec 31, 2009 | 12:50 PM
DJYoshaBYD's Avatar
well, your vid didnt show up.. i cant watch youtube videos at work.. lol
well, get some jacks.. borrow some to get under it and check..
does the sound change with engine speed or car speed?
Old Dec 31, 2009 | 12:57 PM
DC2many's Avatar
mostly only decel in gear and when i don't press the brakes around 3k and below
but it doesn't happen all the time.
no chance of borrowing tools now its newyears eve and new years soon.
argh hopefully nothing major but it must be something major to be making such a sound...
Old Dec 31, 2009 | 01:02 PM
DJYoshaBYD's Avatar
i mean, you may have broke an engine mount or something, and its making a rubbing sound from vibrating against the car, or something..
have you looked in your trunk for a jack? like, EVERY CAR comes with a small jack... just ask around if you can use someones.. that would help us see whats going on...
Old Dec 31, 2009 | 01:17 PM
GagnarTheUnruly's Avatar
I'd guess it's an exhaust or heat shield rattle. You could try hitting the A-pipe and cat with a mallet and seeing if you hear something. You could also check the engine mounts and torque mounts. A visual inspection is the first place to start. Also, anything that is rpm dependent (happens always at the same engine speed) suggests an exhaust system issue.
Old Dec 31, 2009 | 01:36 PM
DC2many's Avatar
i hope thats the case, sounds like a simple fix but the sound is like a goose call...
i <3 my spec 2 and i hurt her so badly
my poor spec 2
Old Dec 31, 2009 | 01:38 PM
I couldn't find the sound on the vid. Where is it (like 2:43 or whatever)?
Old Dec 31, 2009 | 01:40 PM
DC2many's Avatar
i have them listed on description, its hard to hear because of the camera phone
but if you check the subbie video i have on the description as well that is what it sounds like.
sounds horrid...
Old Dec 31, 2009 | 10:29 PM
PowerLeg's Avatar
bump for this guy the problem sounds like some bad ****
Old Jan 3, 2010 | 12:21 AM
DC2many's Avatar
bump this is bad, cant really take it to a shop nad have to pay for them to look for a sound that doesnt show up too often.
gonna waste so much gas decelling from 4k every single time
Old Jan 3, 2010 | 08:02 AM
A couple things to try:
1) Actually look to see if anything looks bent or cracked
2) Try to get the noise to happen while you are free-revving in your driveway
If it's rpm-dependent it's likely to be a heat shield or exhaust system rattle. If you have a stock header it could have a broken piece inside. If you have a cat you could've broken a baffle -- likewise for the muffler.
Get the car on jacks, look around, and hit things with a mallet.
preludedriversh
Jan 9, 2007 06:56 PM
Lifter2012
Sep 30, 2005 05:38 PM
JDM_Type-R
Jul 29, 2004 05:24 AM
91sihatchback
Jun 23, 2003 06:04 PM
shadowdawn
Aug 4, 2002 09:48 AM
