noise from suspension in EM1?
Old Dec 24, 2009 | 07:16 AM
slateEKsi's Avatar
Icon2 noise from suspension in EM1?
There is a loud noise coming from the rear passenger side of the car. It sounds almost like something is hitting off of my lca. I checked and its not my exhaust. If i had a bushing that was really bad, would it be capable of making a loud clunking noise? Maybe my rear trailing arm bushing is bad or something?
Old Dec 24, 2009 | 07:23 AM
delsolproblems's Avatar
Default Re: noise from suspension in EM1?
Did you check the dust guard for the brake?
Old Dec 24, 2009 | 08:54 AM
slateEKsi's Avatar
no i didn't, but i think the noise is louder and maybe has more to do with the action of the suspension- i will check that though just in case its hitting on something
Old Dec 24, 2009 | 06:35 PM
slateEKsi's Avatar
any other advice?
Old Dec 24, 2009 | 06:54 PM
If you can reproduce the noise by bouncing the corner of the car manually, have someone do that while you look for where the it's coming from.
Old Dec 24, 2009 | 07:43 PM
D Griff's Avatar
When does it happen? Over bumps, slow turns, stopping?
Old Dec 24, 2009 | 08:09 PM
Griff has a good point, please explain the sound some more. Is it repititious as the wheel turns? When you said it sounded like something hitting your LCA, I kinda assumed it was when going over bumps, sorry.
Old Dec 24, 2009 | 08:15 PM
z395civic's Avatar
poss a busted end link?
Old Jul 18, 2019 | 06:28 AM
avdrumdad's Avatar
Did you ever solve this mystery?
Old Jun 27, 2021 | 06:36 PM
Pantera96's Avatar
I hate it when people ask questions but don't show up once they find the answer. I'm having a similar issue.
Old Jun 27, 2021 | 06:43 PM
Pantera96's Avatar
When going over bumps or over ramps it makes a clunking noise in the rear (I think on the driver side). It started making that noise after I changed the shocks, I then changed the LCAs and the noise is still there. I double checked that every bolt is torqued to spec.
The wheel has some slight movemente when I wiggle it vertically but cannot replicate it when doing so horizontally. All the bushings seems to be ok.
The noise it's pretty loud and it sounds like it's something bolted to the chasis. I don't have a rear swaybar.
Did someone have a similar issue? Do you have an idea of what could be causing this?
Old Jun 28, 2021 | 08:00 AM
NukeNinja's Avatar
Besides the lower mount screw, and three upper mount screws, there is also the center stud holding the strut assembly together. If not tightened far enough, the strut itself will make noise as it unloads and loads. Just a thought, because I have had this issue. It can be tightened without removing the strut.
Old Jun 28, 2021 | 09:54 AM
Pantera96's Avatar
Hm true. Do you know the torque spec? I will test it out later today and post an update whether that solves it or not. Thanks
Old Jun 28, 2021 | 01:42 PM
tony_2018's Avatar
Fish Twig
Tighten as best you can.
Old Jun 29, 2021 | 06:12 PM
Pantera96's Avatar
Update: I tried tightening those nuts as best as I could but it made no difference. I will probably call the workshop that did the suspension install and let them figure out whats wrong. I will post an update once I find what is causing this issue.
Old Aug 10, 2021 | 04:43 PM
Pantera96's Avatar
Turns out the noise was the spring being loose and hitting the top of the shock under compression.
jorge59la
Dec 1, 2010 12:01 AM
skip.two
Suspension & Brakes
Jun 14, 2009 07:38 AM
xmr. robotox
Suspension & Brakes
Apr 30, 2006 12:44 PM
WPG_5thgenprelude
Jan 11, 2005 03:37 PM
