2 problems with my eg..break and idle
Old Dec 23, 2009 | 07:24 PM
724chris's Avatar
Default 2 problems with my eg..break and idle
1. okwhen i hit my brakes they go to the floor and when i pump the pedal it gets harder..i bled the brakes and it did nothing..what could it be?
2. the other problem im having is when im sitting at a red light my car idles soo low that it almost stalls out(did once) but is seems when i turn my heater on the itle goes up to normal.. it seems real weird to me but can anyone help me out?
Old Dec 23, 2009 | 08:20 PM
Luserkid's Avatar
Default Re: 2 problems with my eg..break and idle
Bad master cylinder could cause this or break in the lines
Whats your idle normal? Is your idle screw adjusted correctly? Could be idle screw, dirty iac, or dirty fitv.
Old Dec 23, 2009 | 08:48 PM
Mangotreemechanic's Avatar
Icon6 Re: 2 problems with my eg..break and idle
1. Your brake system has a leak somewhere, anywhere. Do you have to fill up the reservoir at the master brake cylinder? Then the leak is spilling fluid somewhere. Go to look for the fluid on parts of the car. If the reservoir does not need filling, then the master cylinder itself has an internal leak (fluid gets past the seals). Replace or rebuild the master cylinder.
2. If engine runs fine but idle is too low, adjust the idle higher. You might have an idle screw in the throttle body. You might also have an idle adjustment at a mechanical position along your throttle cable and lever arm system. If your engine is not running smooth or well, then you have other problems. Need more clues then.
Check carefully. I am sure you will find the problem.
muddmonky
11
Jan 24, 2013 05:34 AM
Bhh2000
Nov 14, 2012 05:15 PM
littleblue
15
Sep 2, 2009 06:59 AM
seeodywhy
Jul 19, 2009 11:30 AM
u_gnit
Aug 11, 2006 09:21 AM
