auto ------->5speed
Old Sep 3, 2002 | 11:57 AM
turbo sol's Avatar
Default auto ------->5speed
i have an automatic d16z in my garage with low miles and a high mile d16z manual in my car. Waht do i need to do to make my 5speed bolt up to the transmission?
Do i need to remove the torque convertor and put in a regula fly wheel? if so what civc's can i pull a flywheen from? any help woudld be nice, i did a search and nothign about a new flywheel was ever talked about.
Old Sep 3, 2002 | 12:45 PM
Spade's Avatar
Default Re: auto ------->5speed (turbo sol)
Any D series will have a flywheel that will work for you.
Old Sep 3, 2002 | 12:48 PM
turbo sol's Avatar
Default Re: auto ------->5speed (Spade)
so i all i need to do is take off the torque convertor and put on a d series fly wheel? What is the max weight you can turn off of a flywheel?
Old Sep 3, 2002 | 01:00 PM
Spade's Avatar
Max weight to remove?
Don't make it any lighter than 12.5 lbs and balance it to 9000 RPMs.
Or spend the 250 on a already light flywheel.
You will also need the clutch, clutch master cylinder, slave cylinder and piping.
turbo_d
Feb 24, 2010 08:43 PM
gsrsuperman
Mid-Atlantic (Sales)
Dec 12, 2007 09:22 PM
redmethods
May 25, 2004 04:39 PM
lunarcry
Jan 9, 2003 11:53 PM
