clearances on a d16y8 Crower stg2 turbo cam, SI 1mm over valves
Old Dec 23, 2009 | 01:17 PM
wingsEK's Avatar
Default clearances on a d16y8 Crower stg2 turbo cam, SI 1mm over valves
Does anybody know the recommended clearances(piston/valve, valve/valve) for a Crower stg2 turbo cam with SI 1mm over valves for a d16y8?
Old Dec 26, 2009 | 11:49 PM
wingsEK's Avatar
Default Re: clearances on a d16y8 Crower stg2 turbo cam, SI 1mm over valves
bump
Old Dec 27, 2009 | 01:22 AM
clutchrsx's Avatar
first off.. do you know how to clay the motor while locking it in vtec?
what compression pistons? i highly doubt you'll have clearance issues with low compression pistons unless the cams are that "crazy"
Old Dec 30, 2009 | 03:14 AM
wingsEK's Avatar
the cam is a crower stage 2 turbo cam and the pistons are stock for the time being. im burnin hella oil (burnt up valves) with the head thats on it right now so im forced to put this one on it until i can get my other bottom end back so i need to know if this will clear or not. im gonna clay it regardless but i dont feel like doin it unless i have good reason to believe it will fit. my other block has low compression pistons but its gonna be a while until i get it back.
Old Dec 30, 2009 | 12:03 PM
clutchrsx's Avatar
i can't tell you if it clears or not since i've never had that particular set up. but i'd clay it anyways.. doesn't take much time. i highly doubt you'll have clearance issues.
your problem with burning oil - i doubt that's associated with a burnt valve. if u are constantly burning oil, it's probably your rings. if u are burning oil on start up.. it's most likely your stem seals.
even if u slap that head on, do u have a map to properly run that head? goodluck
j.packsb
Mar 3, 2010 08:50 AM
xkrazyxjbrkerx75
Jul 25, 2009 11:56 AM
Rob1242
Apr 8, 2005 04:19 AM
projectTeG
Mar 13, 2005 12:16 PM
Pfieff
Apr 23, 2004 11:08 AM
