any1 here using 92-95 (EG) forks to fit newer struts in the front?
Old Sep 3, 2002 | 11:41 AM
Agent Daimon's Avatar
Default any1 here using 92-95 (EG) forks to fit newer struts in the front?
if you are does it raise up your car a little bit?i heard 92-95 forks are a little longer than 88-91 forks? if anyone has them on their car..please tell me whats up..thanks.
Old Sep 3, 2002 | 01:09 PM
REDBARON's Avatar
Default Re: any1 here using 92-95 (EG) forks to fit newer struts in the front? (RIPDC2)
I have them. I'm not sure about it raising your car up, but I can tell you that it really minimizes the shock travel in the front. I have it lowered approx 1" and the front shocks have very little shock travel left. I'm working on getting some CRX shocks now.
Old Sep 3, 2002 | 02:48 PM
Default Re: any1 here using 92-95 (REDBARON)
its because i have 92-95 civic tokico adjustables sitting in my garage..and i want to use them..or should i just get some 88-91 struts..hmm..which is cheaper? eg forks or 88-91 struts..
Old Sep 3, 2002 | 03:11 PM
primoEF's Avatar
Default Re: any1 here using 92-95 (RIPDC2)
i would just get the EG forks and use the shocks, I think they are much cheaper than getting new shocks for EF
Old Sep 3, 2002 | 03:37 PM
crx-er's Avatar
I had EG shocks on my 90 Civic Si before. The shocks can bottom out quite easily if your springs lower your car more than 1.5 inches. It is not a good feeling when you are rounding a turn and you have used up all your shock travel. All you would get is massive understeer.
Old Jan 3, 2007 | 06:22 PM
jpciii's Avatar
Default Re: any1 here using 92-95 (crx-er)
bumping an old thread for more input. I'm thinking of going this route with a wagovan...
hondapimp125
Suspension & Brakes
Mar 8, 2008 11:26 PM
wakaranai
Oct 14, 2007 12:46 PM
chindian
Mar 15, 2007 05:45 PM
JuanK20
Mar 31, 2006 03:52 PM
Steve91
Feb 26, 2003 04:49 PM
