DA struts/shocks into a EG?? Help
Re: DA struts/shocks into a EG?? Help (.JDM KiD.)
they will work but the diameter where the fork goes over is different. the EG fork is wider so it wont want to bolt nicely to the DA/EF shock. you can use the DA fork in the EG, and it'll work. not the best combo but it works as Ive done it in the past.
94-2000 integra and 92-95 civic dampers are the same part number in every catatlog i have ever seen. the forks, damper, lca, spindle, all is the same so its all interchangeable.
Re: (schardbody)
because i have aftermarket shocks here laying around so im wondering if they will fit. thanks for the help ppl!
chindian
03-15-2007 05:45 PM
