b18 crx getting fuel but no fire
Old Dec 23, 2009 | 10:42 AM
londoncrx's Avatar
Default b18 crx getting fuel but no fire
i had a cut harness in the crx so i got a new and was gonna switch them out so i did yesterday and now it dont wanna seen to get any fire but i know its getting fuel and the ecu ground is hooked up all the fuses are good any other idea
Old Dec 23, 2009 | 10:48 AM
hamorhead's Avatar
Default Re: b18 crx getting fuel but no fire
is thetiming off?
Old Dec 23, 2009 | 10:51 AM
londoncrx's Avatar
nope i checked it jumped time the other day so i thought that could be it too any other ideas
Old Dec 23, 2009 | 11:33 AM
89s1's Avatar
check the compression, if you jumped the timing bad you could have bent some valves.
Old Dec 23, 2009 | 11:43 AM
placid888's Avatar
does it have spark?? first thing to check before doing anything else
Old Dec 23, 2009 | 09:39 PM
londoncrx's Avatar
idk if it has spark noone was helping me so i didnt check it ran fine before i shut it off to swich them out but imm assuming it dosent have spark so would could be causing that
Old Dec 24, 2009 | 09:34 AM
londoncrx's Avatar
neone
Old Dec 24, 2009 | 12:03 PM
londoncrx's Avatar
ok what would make it spark once and then not again it sparks as soon as u start to crank then stops
Corvair64
Dec 27, 2009 02:10 PM
91rexhf
40
Jan 27, 2009 09:45 PM
n3h3bkau
Nov 2, 2007 10:51 AM
draw
20
Nov 22, 2004 08:33 AM
g2turbo
Sep 17, 2003 08:31 PM
