Suspension & Brakes Theory, alignment, spring rates....
Function 7 LCA's with Blox rear sway bar?!?!
Old Dec 23, 2009 | 02:28 AM
die_lawn's Avatar
Default Function 7 LCA's with Blox rear sway bar?!?!
so i went to go throw everything on today and i ran into a problem with the endlinks not being long enough to meet up with the mounting points on the LCA's. the sway bar is about an inch or so short, is anyone running this same setup? this is on a 96 Del Sol S also if it makes a difference. thanks in advance.
Old Dec 23, 2009 | 07:19 AM
JW racing's Avatar
Default Re: Function 7 LCA's with Blox rear sway bar?!?!
You have to get some sort of adjustable endlink,like Function7 has and then you can adjust and set the length correctly.
Old Dec 23, 2009 | 09:47 PM
die_lawn's Avatar
Ok well I just picked up a new set of F7's and they're different from the ones that I have. Mines are the older ones I guess, they only have one hole for the sway bar mounting, to where the new ones have 3 holes.. Thanks anyways!
StockDC2
Honda CR-V & Element
Oct 14, 2015 03:22 PM
DarkBB4
Feb 1, 2006 01:16 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
bearboy80
Apr 29, 2003 03:48 PM
