DILEMA: Azines tire size??? is 215 too big for 16x7?
Old Sep 3, 2002 | 11:30 AM
92TypeR's Avatar
FSAE
Default DILEMA: Azines tire size??? is 215 too big for 16x7?
Ok, just ordered slipstream 16x7's, and came to the realization that the tire I was hoping to get (Azines) does not come in a 205/45 or even 205/50!! The only 205 size is 205/55! That is WAY to big. That leaves me with the 215/45...is that too big? The car will be about 1-1.5 inches lower than stock. Thanks.
Old Sep 3, 2002 | 11:33 AM
Austin's Avatar
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (92TypeR)
It will be very close to rubbing...with the 215-45/16 on Mugen MF-10's, +43mm offset I had a very slight rub under full lock
Old Sep 3, 2002 | 11:37 AM
jeff652's Avatar
The 215/45 16 is the size used by Honda of Japan on the 98+ 16" Type R rims. You may have slight rub at full lock, but you'll be fine overall, assuming you got the correct offset Slipstreams . . .
HTH
Jeff
Old Sep 3, 2002 | 11:38 AM
92TypeR's Avatar
FSAE
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (jeff652)
+40mm offset is what I ordered...I can change it to +45mm if i call soon, otherwise i'll be stuck with the 40mm.
Old Sep 3, 2002 | 11:39 AM
Cosworth's Avatar
Do you have GS-R rear LCA or ITR rear LCA? I think you might have a problem with rear tires rubbing with 215/45/16 on GS-R suspension setup...
Old Sep 3, 2002 | 11:43 AM
92TypeR's Avatar
FSAE
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (Cosworth)
ITR control arms, buddyclub dampers.
Old Sep 3, 2002 | 11:53 AM
Bbasso's Avatar
is the GSR offset like 10mm diff then a ITR????
Old Sep 3, 2002 | 12:00 PM
StageOne's Avatar
I had slight rubbing on the rear fender lip with 16x7 and +45 offset, and the stock ITR setup. I switched to B6s and with it lowered (~.5) there is no more rubbing. I would go with the +45 offset, I think the +40 will push it out to much, but with that much of a drop you may rub anyways.
Old Sep 3, 2002 | 12:05 PM
jeff652's Avatar
What's the offset of the 16" JDM Type R wheels?
I'd think 45mm would be the better bet . . . considering the Type R track is 5mm wider on each side (compared to GSR/LS) . . .
Old Sep 3, 2002 | 12:11 PM
Big Phat R's Avatar
As you can see, it depends on the offset of the rim.
16x7 +50mm offset can fit a 225/40-16
16X7 +43mm offset can fit a 215/45-16
with a 40 mm offset you will still be able to fit a 215 but you might encounter rubbing on the inside of the fender wells or while at full lock.
Old Sep 3, 2002 | 12:54 PM
vwong's Avatar
I have 16x7 Volk SE37K (+42mm offset) on 215/45 Azenis, dropped about 1.75" with TEIN HA, I have no problem at all.
When I first bought the Volks, I had 225/45R16 S-03 front and 205/50R16 S-03 rear. BTW, keep in mind that both sizes are about 3/8" larger in O.D. than the 215/45R16. I had slight rubbing in the front when the steering wheel was at full lock, and slight rubbing in the rear under hard corning.
Old Sep 3, 2002 | 01:25 PM
AllMotorITR's Avatar
New User
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (vwong)
Sorry to semi-change the subject, but will I have rubbing issues with 205-50-15 G Force Drag Radials on my stock ITR rims? My R is dropped ~1.5"
Old Sep 3, 2002 | 01:38 PM
92TypeR's Avatar
FSAE
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (Boostin ITR)
So, would 45 be better than 40 with 215/45?
Old Sep 3, 2002 | 01:43 PM
Big Phat R's Avatar
Yes
Old Sep 3, 2002 | 04:50 PM
Jon7's Avatar
Default Re: DILEMA: Azines tire size??? is 215 too big for 16x7? (Big Phat R)
I have te37s in 16x7 at a 42mm offset with 215/45/16s p7000s and about a 1.5 inch drop with no rubbing.
Old Sep 3, 2002 | 05:00 PM
bb6h22a's Avatar
Default I use.
..+ 45mm 16*7 slipstreams w/ 215*45 azenis; no rubbing at all, it's why I got the +45mm offset.
Old Sep 3, 2002 | 05:23 PM
92TypeR's Avatar
FSAE
Default Re: I use. (bb6h22a)
Ok, just switched the order to 45mm offset. Thanks every1.
roller3804
Feb 23, 2007 07:40 PM
93civicEX
Mar 31, 2006 08:16 AM
aznwash3wboi
Sep 12, 2005 01:12 AM
RTW DC2R
Feb 3, 2003 08:54 PM
Initial_E
Dec 5, 2001 01:44 AM
