Compression tester adapter stuck in spark plug hole!!!!
Old Dec 22, 2009 | 05:30 PM
Luck6's Avatar
Default Compression tester adapter stuck in spark plug hole!!!!
I was doing a compression test when i tryed unscrewing the tester the adapter stayed in the whole. does anyone know of a way to take the adapter off ? I'm planning on using red loc tite on the tester and screwing it in letting it sit and see if i can remove it like that.
Old Dec 22, 2009 | 06:06 PM
jbrokos307's Avatar
Default Re: Compression tester adapter stuck in spark plug hole!!!!
theres not at bolt like end to it if its loose enough long needle nose pliers open it up stick one of the pointed ends in the test port and try to unscrew it
Old Dec 22, 2009 | 08:14 PM
delinquent's Avatar
same thing happened to me. we used a perfect sized flat head, and hammered it gently into the adapter and screwed it out.
Old Dec 22, 2009 | 08:44 PM
Luck6's Avatar
I'm ****ed i used loctite on the hose and put it back on know i can't get it off. I guess i showed start looking for a new head huh ?
Old Dec 22, 2009 | 09:21 PM
Luck6's Avatar
Guys i really need some help, I tryed doing a compression test and when i tryed screwing the spark plug in. The adapter that connects to the comp. tester stayed in the spark plug hole. I tryed everything to get it out, i put loctite on the thread on the hose and screwed that in. As soon as i come in the house to talk to my friend about it and explain to him. He reminded me that the force i used tighting the spark plug might have tighten the adapter further inside aswell, 30 minutes past and he tells me that the adapter is not going to be easy to take out with the hose inside because its not hand tighten the spark plug forced it in deeper and harder to get out. Well know the hose is stuck on and woun't come out. If anyone can help me please do i really need someone to help me on this. Sorry for the long writing thx to everyone.
Old Dec 22, 2009 | 10:35 PM
Davidss's Avatar
Start by taking off the valve cover. This will allow you to get closer to the problem.
Old Dec 23, 2009 | 03:02 PM
delinquent's Avatar
u kinda fked yourself when you loctited the hose onto the fitting..i'm not sure what to tell u now, but if u can get the hose off try finding a flat head to hammer into the adapter without breaking it and then back it out.
Old Dec 23, 2009 | 06:00 PM
dr_latino999's Avatar
~Thud~
I did the same thing back in 2005, I ended up just taking off the head to remove it.
Old Dec 23, 2009 | 06:18 PM
onepoint6i's Avatar
do what davidss said, take off the valve cover to start..go to harbor freight and buy your self some long needle nose pliers and try to see if you can twist it off with those...good luck..
Old Dec 23, 2009 | 07:11 PM
35r'DHyBriD's Avatar
^^^^^^ X2 DONT TAKE OFF YOU HEAD !!!!!!!!!!!!!!!!!!! Get some long neddel nose and grab it with valve cover off and unscrew it
Old Dec 24, 2009 | 09:12 AM
Grnnt4's Avatar
The same thing happened to me, I pounded a flathead screwdriver into the fitting, thing was in there tight, but I got it out w/o removing the head thank god.
Old Dec 24, 2009 | 09:32 AM
Good luck with that. Let's do some basic math:
Diameter of spark plug tube.
Depth of spark plug tube.
Diameter of extruding bit of tester.
You have to be really lucky to find a pair of pliers that will open wide enough to grab the extruded part, yet not hit the walls of the spark plug tube. You will also have the issue of getting enough "grip" on the part to apply the torque directly along the rotational axis.
Old Dec 24, 2009 | 10:12 AM
beansandrice's Avatar
For real! You guys act like removing a head is freaking rocket science.
Old Dec 24, 2009 | 11:57 AM
Yeah true ... it's not but it just sometimess becomes a bitch ....
I just had this happen to my roomie last week and the long skinny set of crapsman needle nose i have did the job just fine. I just don't think the idea of putting a flat blade screwdriver in my head and "beating" on it sound like a good plan for my motor but opinions are like escalades everybodys got one ...
Old Dec 24, 2009 | 11:59 AM
EF-Devotion's Avatar
This has happened to me in times. Screw the thing back into the adapter and start the car again to get compression into the cylinder, then don't release the air out and turn and the adapter should come out. When there's pressure in the cylinder the adapter will come out.
Old Dec 24, 2009 | 12:04 PM
damn you do learn something new everyday d@mn man nice brain skills !
Old Dec 24, 2009 | 12:28 PM
angel_i's Avatar
did it work?
Old Apr 9, 2013 | 08:32 PM
Mishako129's Avatar
I've having the exact same problem, I used loctite on the compression tester to try and get the adapter to come out. The hose just kept spinning.
Now i'm stuck.
Old Apr 9, 2013 | 08:50 PM
V.MoMO's Avatar
really thin and long needle noses are ur best friend
Old Apr 9, 2013 | 08:56 PM
Mishako129's Avatar
i tried that it didn't work.
Lewy. Dee Ayy's Avatar
I had this happen to a friends car...It took 3 days to get it out...We ran the car on 3 cylinders to help heat it up and expand the metal and then took really skinny long needle nose and got it out.
Old Apr 9, 2013 | 09:16 PM
Mishako129's Avatar
Like these?
If you would take a minute I have a thread about a different problem but I think the two are related. The spark plug where the adapter was stuck got really damaged, I don't know what happened.
Here's the link,
http://www.cb7tuner.com/vbb/showthread.php?t=198722
Old Apr 9, 2013 | 10:15 PM
Son2BEHO's Avatar
Can you get the valve cover off? Maybe a picture if u can get one
Old Apr 9, 2013 | 10:16 PM
ef_cowboy's Avatar
Stick a exstractor or a tap on the hole of the tool that is stuck
Old Jun 13, 2015 | 04:50 PM
mlw1234's Avatar
My boyfriend just got it out by unscrewing it with the spark plug wrench.
gjbraun
Jun 18, 2012 10:57 AM
drumminforev
Jan 21, 2007 08:59 AM
NegativeXero
11
Aug 18, 2006 06:52 PM
Teg4e
Jun 29, 2006 02:24 PM
