Broken steering column replacement?
Old Dec 22, 2009 | 02:35 PM
PYITR01's Avatar
Default Broken steering column replacement?
i bought a shell and the steering column is broken the lock assy is also missing where the key goes in. i do have the original key the car came with, i just dont want to have to replace the steering column lock assy and have two sets of keys. do i have to replace all the locks to have one set of keys?
thanks
Old Dec 22, 2009 | 02:44 PM
97ITR#126's Avatar
Default Re: Broken steering column replacement?
Yeah you will need to replace all of the locks if you want to use 1 key. When I rebuilt my EM1 Honda said that's the only way. I had 2 keys. One to get in the door and one for the ignition.
Old Dec 22, 2009 | 03:01 PM
Seedc2's Avatar
its unfortunate, but you will need to use 2 separate keys to open the door and start the ignition.
Someone attempted to steal my car and broke the ignition. Now I am having to use 2 keys... its a pita but what can you do.
Old Dec 22, 2009 | 03:09 PM
PYITR01's Avatar
if i order it from acura online will they send me everything including the keys cut already or will i have to bring it to a lock smith or acura to cut it.
Old Dec 22, 2009 | 03:37 PM
99SlammedCivic's Avatar
Snipper Snapper
94rs-Turbo posting------
I hope you guys know that honda has the key pins at the dealership so you can rekey the lock to have one matching key again, I use to do that when I worked there same pins for honda and acura keys
Old Dec 23, 2009 | 04:53 AM
sheekdude's Avatar
For door locks yes, but i've never heard of them doing ignition switches...
Old Dec 23, 2009 | 07:12 AM
Notorious92rhdEG's Avatar
yeah so just get a new ignition and whatever key that comes with just have them re-key the door locks to the key that comes with the new ignition. you will then have 1 key for everything.
Old Dec 23, 2009 | 08:51 AM
94rs-turbo's Avatar
like i said before, you can rekey the car including the ignition. so just rekey the ignition and keep your original keys and not have to reprogram the immobilizer either
Old Dec 23, 2009 | 05:25 PM
JDM-jerm's Avatar
And the dealer does this?
Old Dec 24, 2009 | 09:44 AM
94rs-turbo's Avatar
they have a clear white box at the parts dept. that has all the different pins #1-6 to match the key, every honda/acura dealer should have this. If they dont then they're dumb lol
SoCalCivic498
Apr 20, 2015 08:37 PM
bscottclarrk
Jan 2, 2012 02:50 PM
punkracer
Jul 12, 2005 09:51 PM
