need help with 02 sensors
Old Dec 22, 2009 | 11:42 AM
smokey68321's Avatar
Default need help with 02 sensors
ok so i've searched and searched been searching since 9:00 this morning and all i can find is how to pin the 02 sensors to the ecu... my question is on what USDM motor do i get the two 02 Sensors off of since i got the JDM B16a its OBD0 with the PR3 ecu and it has two on the exhaust manifold and the Del Sol only has one and the LS only has one so im stumped.... also i have no CEL for the 02 sensor's... will the car pass emmisions with them unhooked? do i need to hook them up?
Old Dec 22, 2009 | 11:45 AM
frank_el_tanke's Avatar
Default Re: need help with 02 sensors
you need to use single wire o2 sensors, buy 2 of them. 88-91 civic/crx
Old Dec 22, 2009 | 11:58 AM
so it'll still be the same just get it for the 91 civic which what the car is? but theres the white round plug and the green square plug... i was under ther impression that i could use parts from a del sol vtec and an Integra LS since i found this link http://hondaswap.com/hybrid-ed-ef-da...ts-list-25241/
and here are a few pictures
Old Dec 22, 2009 | 12:56 PM
who did your wiring? the round plug i would use as the primary o2 sensor, the second o2 sensor wire it to the secondary. plug shapes don't matter, you can use any plug by cutting and soldering.
Old Dec 22, 2009 | 02:12 PM
yeah i know the wiring is all messed up.. it this dude that lives around here... im in the process of getting everything hooked up straight and look decent... but i need to change both 02 sensors what do i get them out of?
Old Dec 22, 2009 | 05:54 PM
HondaPartsHero's Avatar
Technical Hero
get them for 90-91 integra or 88-91 civic/crx just get the universal styel and solder the connections
Old Dec 22, 2009 | 06:16 PM
i suck at soldering.... but i looked at a 90 Integra LS but i dont have those conections to solder on and i've seen that picture... is there a place online that would sell the 02 sensors i need? should the one from the civic already have the white ciricle one? would it be a good idea to wire the two 02 sensors together?
i might just convert to OBD1 should make things alot easier
Old Dec 22, 2009 | 06:33 PM
crx_si-r's Avatar
dont solder any connections. just take a precision screw driver and re-pin the connectors. that all you have to do.
Old Dec 22, 2009 | 07:22 PM
ok thanks, i got all that but where can i get the connections because the US doesnt have the green connector and i dont have the wires from the 02 sensors to the plug in
Old Dec 22, 2009 | 08:11 PM
EJ1_Sleeper's Avatar
go to a junkyard and get a USDM o2 plug, then repin your JDM o2 plug to the USDM plug then get 2 o2 sensors and plug them in (looks like you need to go to a junkyard and cut 2 plugs off from the OEM o2s themselves) then you just plug each one in the correct spot and tada 2 working 02 sensors. if you need i can snip the oem plugs, im goin to the yard tomorrow.
Old Dec 22, 2009 | 08:14 PM
ok so just wire both 02's into the white circle plug? if im getting that right just run both 02's into one plug?
Old Dec 22, 2009 | 10:38 PM
no, each o2 sensor has a different location at the ecu. hondapartshero gave u the info and you also searched this info... go to the junk yard and get the plugs off any honda/acura wiring harness that is obd0. most use the same style plugs all you have to do is look at the plugs.
Old Dec 23, 2009 | 06:05 AM
oh ok so from the two plugs just cut the wires and run new ones to the ECU? and the 90 tegs/civics have the green square plug and white circle plug? ....
Old Dec 23, 2009 | 03:55 PM
yes. yes. you can use the purge solenoid plug, it's the same as the square o2 sensor plug... located on the firewall near the map sensor.
Old Dec 23, 2009 | 04:16 PM
ok i much appreciate the help on that, so when buying new 02 sensors just get the universal ones? do i have to solder anything?... and the purge solenoid plug will plug right into the green plug thats already in the picture?
Old Dec 23, 2009 | 06:46 PM
Technical Hero
Autozone has the universal for 19.99 and the plug and play one for 38. If you get one universal and solder the purge solenoid plug onto it it will plug into the green plug. Then buy one plug and play and it will plug into the white circular one. The US integra (90-91) only has one O2 (circular style). If you need the plug for the green sensor and don't have one PM me I'll send you one for free
Old Dec 24, 2009 | 09:16 AM
thanks, i appreciate every's help now i just gotta find someone who can solder good, cause i suck at it and i dont wanna mess it up
Old Dec 24, 2009 | 10:51 AM
ninty1civic's Avatar
soldering is rediculasly easy.. look up a how to do or something.. but i thought dude said you didnt have to solder it, just re-pin the connectors..
Old Dec 24, 2009 | 12:50 PM
yeah but can i re-pin the purge solenoid into the universal 02 sensor? well i take a maintenance class and we learned to solder i just aint very good it would look like crap if i did it aint had much practice at it
Old Dec 24, 2009 | 01:34 PM
vtec_ef8's Avatar
I dont want to thread jack but why does my b16 with a pr3 ecu only has one o2 sensor? Its obd0 also and its on the exhaust where the end of the header and the cat meet.
Old Dec 24, 2009 | 02:05 PM
aftermarket header maybe?
Old Dec 24, 2009 | 02:55 PM
vtec_ef8's Avatar
No it's stock it's cast iron Honda header
Old Dec 24, 2009 | 03:03 PM
hmm i have no clue, but maybe someone on here will know
Old Dec 24, 2009 | 06:04 PM
zrickety's Avatar
maybe it's a b18 header? that one o2 near the cat is not doing anything for you. the car will run rich, it would be the same as disconnecting it. with obd0, you run both o2 near the head like stock, or it doesn't work. your manifold should look like this:
Old Dec 24, 2009 | 07:13 PM
i appreciate that picture i was trying to find where to pin the wires to the ecu and now i know haha
