94 integra radiator in EF: any fitment issues?
I saw that the 90-93 integra radiators will fit 'like a glove' .. but I coulnt find anything on the 94+ integra radiators in our cars..
please let me know
please let me know
neither will fit perfectly....theyre a bit tall. maybe trimming the hood or using an aftermarket lower crossmember with rad supports would lower it enough to clear..
i do believe the rad is wider. what engine do you have in your car? stock d series? cause the hose sizes are larger for the teg radiators.
actually the DA radiator fits in an EF without a prob.. CLIPSED has one in his 4 door and he didnt have to do anything to make it fit..( to my knowledge )
its a bit tall...i tried one in my 91 dx with a b16. i just used an aftermarket ef rad with bigger hose inlets. to the OP. what engine do you have?
wasnt the 94 the first year of the DCs though? or am i mistaken? because you guys keep talking about the DA..
I appreciate the help guys
I too am using the EF rad with my B16 and the previous owner just cut a piece of rubber about an inch wide by 2-3 inches long and wraped that around the inlet and output tubes of the rad. then put the B16 hoses on.. works great.. but yea I have friends that just pinch the **** out of the larger hoses.. (hour-glass looking) but it seems to work..
lunalink.. did you happen to get a chance to try the swap?!
-Chris
-Chris
oh sorry about that, i was taken them apart and my girl ( pregnant ) calls me and makes me rush her to the hospital. but today is 1/2 day at work so I'll have plenty of time today
13 day break FTW!
13 day break FTW!
guys.. I know the 93 fits.. I'm inquiring about the 94+ .. thanks for the info though..
Lunalink.. take all the time you need!!!!!!!! haha
The '94+ integra radiator is the same height as an EG radiator. It will not fit without leaning it. However you cant lean it because the engine is in the way. Just get the correct radiator.
I ran a stock EF rad in my H2B. I had to make a custom upper hose, but I still had stock header clearance and it cooled the engine just fine.
coot_er
Apr 27, 2010 07:02 AM
