95 prelude h22a1 not starting
Old Dec 21, 2009 | 08:38 PM
dcskater56's Avatar
Default 95 prelude h22a1 not starting
We have checked a lot of things. Its getting fuel, air, and spark to the cylinders but still will not start. Does anybody have any ideas on why the car is not starting? Anything would be helpful. Thanks
Old Dec 21, 2009 | 08:56 PM
nus_dogg's Avatar
Default Re: 95 prelude h22a1 not starting
Maybe bad compression?
Old Dec 21, 2009 | 09:43 PM
kornkid21792's Avatar
did you check your starter
Old Dec 21, 2009 | 10:08 PM
Enzo15's Avatar
Sounds like he is getting it to crank, if he is getting fuel and air, and spark into the cylinders. I would say check Comp, Leakage, and the Timing. Altho I think if the starter doesnt crank fast enough it wouldnt let it start up.
Old Dec 21, 2009 | 10:49 PM
dcskater56's Avatar
Yea the car is cranking. We are gonna do a compression test on it tomorrow. Also it looks like the timing may be off by a tooth or so. But still looking at other options to what it could be...
Old Dec 22, 2009 | 07:27 AM
Enzo15's Avatar
Id say fix the timing prob first, because it might throw off your compression numbers.
Old Dec 22, 2009 | 07:31 AM
racingcrx's Avatar
Most likely timing. did you replace the timing belt?
Old Dec 22, 2009 | 06:46 PM
dcskater56's Avatar
yea we are gonna replace the timing belt and hopefully thats what it is.
Z99doc
Apr 28, 2014 06:26 PM
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
Rok_Stok
Feb 10, 2011 09:40 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
kelviiv
Dec 17, 2008 11:19 AM
