how to remove fuse to kill engine?
I think the car won't start if you take out the 15 amp ECU/ECM fuse and the 7.5 AMP back up fuse in the engine bay but why not just put in a hidden fuel pump/kill switch along w/ other security measures...
take out anything related to the pgm fi main relay. i suggest the one under the dashthat sits with another fuse on the top... anotheridea is to take the ecu out
if you want to be safe... take out more than one fuse.
