Fuse Location
Old May 9, 2009 | 06:17 PM
bopbop93030's Avatar
Default Fuse Location
Does it matter where the fuse is located?
I know most of the time its located in the engine bay, but my ANL fuse holder is huge and I have no space in my already cramp engine bay.
Can I put this in the back next to the amp or somewhere in between. Are there any Cons.
Thanks!
Old May 9, 2009 | 09:21 PM
DynastyRacer22's Avatar
Default Re: Fuse Location
leave it a few inches away from the battery you dont want a really high current running through your power wire at a long travel distance
Old May 9, 2009 | 09:37 PM
98civdx's Avatar
Master Detailer
if there is no room under the hood, just find a place in the car to put it.
closer to the bat the better
Old May 9, 2009 | 10:57 PM
mrdeadman's Avatar
They let me pick
A fuse holder is extremely small, and I have a hard time believing you can't fit it in the engine bay. I would keep it in the engine bay so there is less chance your car lights on fire in the event of a short...
Old May 10, 2009 | 12:16 AM
Can this be dangling or it has to be tied down?
My 150 ANL fuse holder is like 2 box of cigarette in height but half the size of the box. I do not have the round fuse holder which is smaller.
Old May 10, 2009 | 07:45 AM
fcm's Avatar
fcm
Old Fart
The fuse must be within 18" of the batt. and in the engine bay, [the fuse is there to protect the power cable] it is best if it is mounted but can "dangle", [depending on type of ANL fuse holder].
Even though basic, this is one of the best ANL fuse holders, [can be left "dangling"]...
http://www.scosche.com/products/productID/1765
They can also be found on eBay...
http://cgi.ebay.com/NEW-Scosche-EWFH...3A1%7C294%3A50
The question is, what kind do you have? 94
Old May 10, 2009 | 04:24 PM
Can you put this on top of the battery and not get any interference?
Old May 10, 2009 | 04:33 PM
fcm's Avatar
fcm
Old Fart
Yes you can, assuming there is room, I have done so more then a few times, because of the batt. hold down it is easy to fab up a bracket to hold the fuse holder, I have even welded a mounting plate to the hold down.
There will be no interference. 94
Old May 10, 2009 | 04:36 PM
On top of the battery it is.
Thanks!
Arthas
Honda Civic (2006 - 2015)
Mar 21, 2012 10:39 AM
CRISWHITEBOY
Jun 17, 2008 11:46 PM
dem0nk1d
Sep 2, 2007 09:45 PM
Jack8788
Jul 9, 2006 07:40 AM
Hoagieryder
Sep 18, 2005 07:16 AM
